Dash cam power 2008 access door
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Knudsen, Aug 16, 2024.
  1. Aug 16, 2024 at 2:55 AM
    Knudsen
    Knudsen [OP] Well-Known Member
    Jon
    2008 Access Door TuRD
    To bet installed: bling grill, headlights, fog lights.
    Hello friends,
    Cam has two power connections. One power on with key on or off - full time power. The other powered on only when running - key switched.
    For the “key switched” power, I’ll use the circuit for the rear power windows that don’t exist on this model. Thank you Toyota.
    What is a good circuit to tap for the “full time power?”
    Full time power is needed for when someone bumps me in the parking lot. I expect minimal power draw from the dash camera on this circuit, but I have not measured it.
    This: https://www.amazon.com/dp/B0BJZQ37G7
    plus
    This: https://www.amazon.com/dp/B0CGXK823B
    is what I’m installing.
    Note: I didn’t and wouldn’t pay the listed price for that dashcam… it was on sale when I ordered it.
  2. Aug 16, 2024 at 6:07 AM
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    You're better off running a fused wire through the firewall. It's super easy.
    Knudsen[OP] likes this.
  3. Aug 16, 2024 at 7:13 AM
    Knudsen
    Jon
    Straight to battery + ?
    I could go there or anywhere in the main fuse box behind the battery.
  4. Aug 16, 2024 at 7:52 AM
    Revelations
    2014 MGM DCSB
    I would go straight to the battery. I only use fuse taps when I plan on using it to trigger a relay on a new circuit.
    Knudsen[QUOTED][OP] likes this.
  5. Aug 16, 2024 at 11:21 AM
    Knudsen
    Jon
    Thanks for the advice :thumbsup:
    Revelations[QUOTED] likes this.
  6. Aug 16, 2024 at 4:28 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Dongar makes an accessory for the electronic mirrors. Im not sure if yours is prewired for that, but i was able to plug that into mine
  7. Aug 17, 2024 at 2:36 AM
    Knudsen
    Jon
    fatfurious2 likes this.
  8. Aug 17, 2024 at 10:19 AM
    gstodd
    gstodd Well-Known Member
    2005 2wd base 5-lug
    I grabbed all my power connection from the wiring for the ignition key. Soldered and fused of course.
