Dash cam recommendations
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tnthomas, Mar 24, 2025.
  1. Mar 24, 2025 at 5:06 PM
    tnthomas
    tnthomas [OP] Active Member
    2019 Tacoma
    I have a 2019 Tacoma that I'd like to add a dash cam to, for all the usual reasons. Having both a front/rear cam would be nice, but the front view cam IMO is more important. So, where to start? Amazon of course has many to choose from, but there's always to usual pitfalls for getting the wrong product. I'm getting less inclined to DIY in my old[er] age lol. Maybe a specialty shop that does stereos, tires and other installs? Of course, I'm up for any easy-peasey installs, maybe something bluetooth with a cellphone app?
    Jaragon likes this.
  2. Mar 24, 2025 at 5:22 PM
    Jaragon
    Jaragon Active Member
    22 TRD Sport - Lunar Rock
    Skid plate for oil changes Cat shields for theft Snail Armor and pop lock tailgate LEDs and custom Inferno accents inside
  3. Mar 24, 2025 at 5:24 PM
    RichochetRabbit
    RichochetRabbit Ping Ping Ping
    If you have a powered mirror, get a Dongar adapter to slave power from that connection.
    Many like FitCamX but maybe not for the 2019 models. Many buy the small almost-micro Garmin models that have no screen but require a BT connection. I use a NextBase 522 but I had it already when I bought the Tacoma and like a screen. Regardless you will NEED a microSD card that writes FAST, minimum 45 MB/sec. My Netbase does not even run with cheap cards, and have a 90 MB/sec-write to be safe.
    Taco y mas, tnthomas[OP] and stihl13 like this.
  4. Mar 24, 2025 at 5:39 PM
    Koolbreeze7
    Koolbreeze7 GRILL MAN
    Jon
    Jersey
    2017 TRD Sport 4x4 DCLB Black, Trail Limo. RIP- 2009, 2000, 91,89,87 trucks
    Rigid pod fogs, SpartanX stealth grill and hood LED's, 17" SEMA's on 275/70/17 Falken Wildpeak AT3W's, Fox 2.0 on all corners , TRD CAI, LEER 100XQ Blacked out, w/ Thule racks, and Cargo slider Flow master American Thunder "dual" exhaust, remote start, tint, TRD Pro grill and TRD shadow graphics, Alcan custom 8 leaf Spring Pack
    I TOO have the Garmin mini 2 and the dongar adapter. small and out of sight. easy to install. software isn't difficult. I ALSO recommend
  5. Mar 24, 2025 at 5:43 PM
    fiftysix
    fiftysix Mell-Known Wember
    Midwest
    2023 TRD OR
    I have garmin mini 3 and dongar, no complaints
    tnthomas[OP] likes this.
  6. Mar 24, 2025 at 5:45 PM
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    Yes, as others have said, Garmin Mini 2 with the Dongar adapter. Can’t go wrong.
    tnthomas[OP] and Jaragon like this.
  7. Mar 24, 2025 at 5:50 PM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    Hands down the wolfbox is worth the money. The G850pro just came out and will give you blind spot and pedestrian detection as well as a crystal clear back up cam and front/rear dash cam all in one.
  8. Mar 25, 2025 at 12:39 PM
    majpooper
    majpooper Well-Known Member
    Dennis
    North Carolina
    2022 Black TRD OR
    OTT Tune Front 2" lift OME 888 coil Bilstein 5100 DuroBump extended front bump stops Archive Garage extended rear bump stops Rear 1.85" lift Icon RXT leaf pack Bilstein 5100 SPC UCA DX4 16x8 +10 wheels 285/75R16 KO2 viper cut CMC sway bar delete exhaust reroute exhaust cut just past the rear axle U-bolt flip LFD engine skid plate RCI transmission and x-fer case skid plates Spindle gussets
    After watching a shit load of videos and researching I found out there are basically lots of dashcams but the components in all of them are basically the same. There are some with upgraded components that are a little better than the one without the better components but not by much. The real kicker is the price range all over the place so that you can end up paying two or three times more for one dashcam than for one with the same or even less quality components.
    So I went the other route - my dashcam cost less than $1 (actually $0.79) plus shipping costs which was ~$16 or something like that. I plug it in the cigarette lighter and ran the cable under the dash and up the A pillar out of site so the dashcam is high out of the way on the driver side windshield. The battery sucks so running it off the battery is a no-go. and about every 10 days I have to reformat the sd card because it does not over write it like it claims it will but that is easy enough to do (few button clicks in steup - takes about 5 seconds).
    The camera perspective mkes it look bigger and more intrusive than it really is
    https://www.amazon.com/Generic-G-Se...sprefix=dashcam,specialty-aps,113&sr=8-3&th=1
  9. Mar 25, 2025 at 1:21 PM
    Tacorific
    Tacorific Well-Known Member
    NE Iowa
    Barcelona Red 2018 SR5 I4 4X4
    Torque Pro, LED Map & Dome lights, Westin Hitch, Ride Rite Air bags with Daystar perches, Utility Package Rear Cab Panel
    The Viofo lineup is tough to beat for image quality. I have had a A129 Duo since 2021. There are newer units now, with better image quality than the A128, from Viofo and others. YouTube has quite a few vids that compare features and image quality.
    MagicToolbox and tnthomas[OP] like this.
  10. Mar 25, 2025 at 1:29 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Another vote for the Garmin Mini 2.
    Thanks, @TACO-TY !
    TACO-TY likes this.
  11. Mar 25, 2025 at 1:49 PM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    Another vote for the Garmin dash cam here. I’ve had one for several years and it still works like the day I bought it.
  12. Mar 25, 2025 at 2:07 PM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Anyone happen to know if the Dongar adapter works with 3rd gen SR models?
  13. Mar 25, 2025 at 2:11 PM
    ULURU
    ULURU Well-Known Member
    2018 Inferno TRD OR DCSB
    While I have a dash-cam, I am looking for an upgrade / replacement since its internal battery is for shit, and replacing it would be a nightmare (or simply not time well spent considering the cost of a new camera.
    Does anyone have a solution that makes use of the OR's GoPro mount? My current camera supports 1/4"/20 camera mounts, and I have the widgets to connect it to the GP Mount behind the RV Mirror....
  14. Mar 25, 2025 at 2:35 PM
    pushgears
    pushgears Well-Known Member
    2021 OR DCSB MT
    I just happened to see that “Project Farm” dropped a video recently on YouTube in which he reviews dash cams.
    I haven’t watched it yet, so I can’t spoil the suspense.
    joba27n likes this.
  15. Mar 25, 2025 at 3:10 PM
    Sabbathu
    Sabbathu Well-Known Member
    SoCal
    2019 Toyota Tacoma TRD Sport 4x4
    Question regarding the garmin mini 3 adn dongar.... When connecting through the mirror, does the garmin automatically power on when you start up the engine? Or do you have to manually power it on and off all the time?
    MTBTACORN likes this.
  16. Mar 25, 2025 at 3:23 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Sorry as I do not know for the 3, but the 2 powers up automatically when you start. No need to ever touch the camera. The start up / shut off chirp can be turned off in the app settings.
    Jaragon likes this.
  17. Mar 25, 2025 at 3:28 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    Not Karen
    The wild west
    2016 SR5 DCSB
    Aesthetically Challenged
    I also have the garmin mini 2 with Dongar adapter
    I've had it for about a year and no complaints so far.
  18. Mar 25, 2025 at 3:33 PM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    I use a Nextbase 322GW. Comes with everything needed (comes with both adhesive and suction cup windshield mounts), and cigarette-lighter adapter). The cam easily detaches from the (magnetic) windshield mount when needed (maybe for safe-keeping while parked in questionable areas). Resolution is standard HD (1920x1080) 60fps which is pretty good, although capturing license plates more than 40-50 feet away could be better (been thinking of upgrading to the 622GW which is 3840x2160p).
    I used a fuse-tap to an ignition-on source so it's only powered on when the engine is running (didn't think about tapping into power at the mirror until afterward).
    Like mentioned, SD card type is important, but not difficult to find (look for "U3" rated cards, it might also have a claim: "good for 4K UHD video recording" or something similar). I use a Sandisk U3 32GB card.
  19. Mar 25, 2025 at 3:35 PM
    MTBTACORN
    MTBTACORN Well-Known Member
    Ontario, Canada
    23 Tacoma TRD Pro 21 Sportster S
    I have the Garmin Mini 3 with the Dongar Pro. It powers on when the truck is turned on for the setting I have on the Dongar Pro.
  20. Mar 25, 2025 at 3:54 PM
    stihl13
    stihl13 Member
    Florida
    2022 Tacoma TRD Sport
    It looks like the FITCAMX will work with the 2019 tacos and I would recommend you consider it. After installation it’s not obvious it’s there and it is very easy to install and comes with the harness to plug into the factory wiring. There’s lots of YouTube videos that review it. Video quality is good enough for me. The Garmin seems popular but I have no experience with it. As another tw member stated, project farm on YouTube just put out a review on dashcams, I would recommend you check it out. He doesn’t include the FITCAMX but does compare many others
    https://fitcamx.com/products/fitcamx-dash-cam-for-all-toyota?variant=40686041333932
