Dash Cam Reviews
Discussion in 'Product Reviews' started by USDashCamera, Aug 14, 2016.
  1. Nov 22, 2016 at 6:17 AM
    sureshot
    sureshot Well-Known Member
    Middle TN
    2016 TRD Sport
    Nothing yet...
  2. Nov 26, 2016 at 1:36 PM
    BigTex970
    BigTex970 Active Member
    2017 Tacoma TRD OR DCSB
    So looks like from my perspective the best options are:
    Best 1ch image quality in compact camera with parking mode Vicovation Opia2.
    Best 1ch image quality in discrete cam without* parking mode Viofo A119s (*have to manually select it).
    Best 2ch image quality with full features Thinkware F770.
    I was looking for good resolution, capacitor, parking mode, and compact package. Wound up going with Opia2. As a 1 channel the opia2 seems like a better value than Thinkware. Downside is no buffered parking but that's due to ambarella a12 chipset not supporting it yet. Black box my car had sale for $220 on opia2 with 16gb card. Figured I could use this as back up for 128GB card.
    Vicovation recommended Samsung evo or adata premier for 128GB microsd card.
  3. Nov 26, 2016 at 1:39 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
  4. Dec 28, 2016 at 9:52 PM
    USDashCamera
    USDashCamera [OP] Put it in H
    2017 Quicksand TRD OR
    Lord Helmet and Biscuits like this.
  5. Dec 29, 2016 at 6:25 AM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    @USDashCamera what hard wiring kit do you recommend for the power cord?
    I don't like having something plugged in my power socket at all times. It's an OCD :rolleyes:
    By hard wiring it, will it be constantly on? Will I have to power off/on every time?
    I am looking into the A118C
    Maybe TacoCat can provide input?
  6. Dec 29, 2016 at 6:31 AM
    ramonortiz55
    Ramon
    Texas
    stock
  7. Dec 29, 2016 at 6:49 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    I have the cig lighter plug. I looked at the hard wire kit you linked in the following post, but decided to keep it on the lighter socket. I actually have two (front and rear windows) so I use a lighter hub sort of thing. Works well.
  8. Dec 29, 2016 at 6:57 AM
    ramonortiz55
    Ramon
    Texas
    stock
    I am guessing your cig plug only turns on when the truck is on?
    Mine is constantly on.
  9. Dec 29, 2016 at 6:59 AM
    TacoCat
    Johnny-5
    Chantilly, VA
    Correct. I have two plugs in the lower portion below the hvac controls. Both turn on when the truck is set to ACC or higher. I wonder why they would have changed that on the newer model trucks.
  10. Dec 29, 2016 at 7:01 AM
    ramonortiz55
    Ramon
    Texas
    stock
    I modded it to be that way :D
    TacoCat[QUOTED] likes this.
  11. Dec 29, 2016 at 7:04 AM
    TacoCat
    Johnny-5
    Chantilly, VA
    Ohhhh ok gotcha. I have had vehicles in the past that had always hot cig lighter plugs. Most have not though. Wasn't sure if it was a new feature on the newer models.
  12. Dec 29, 2016 at 7:31 AM
    USDashCamera
    if you are just getting something like the A118C, I would just go with this:
    https://www.amazon.com/Spy-Tec-Dash-Camera-Vehicle/dp/B00MH4ZVHO/
    It's cheap, and spytec seems to have a good record. when you connect it, you just have to make sure the red wire is a fuse that is only one when the vehicle is on (but make sure its something that wouldnt cause an issue, only connect it to fuses like the radio or accessory port fuse and not something that is a safety feature). its recommended you use it with an add-a-fuse although there are some kits that are a little higher quality that don't need add-a-fuses or anything extra:
    http://www.thedashcamstore.com/installation-kits/
    https://www.youtube.com/watch?v=yW45vkOfx8E
  13. Dec 29, 2016 at 7:34 AM
    ramonortiz55
    Ramon
    Texas
    stock
    Thank you.
    I have four vehicles, I see a full day mod day coming up soon.
  14. Dec 30, 2016 at 4:34 AM
    dmccurdy7
    dmccurdy7 Lurker
    Doug
    Caldwell, ID
    2010 6MT ACLB TRD Off Road
    Anyone have any input on the suction cups while offroading? Tons of vibration I assume?
    Maybe I missed it but does anyone know of a hard mounting solution specifically for Tacoma's? Or is suction cups the only realistic way?
  15. Dec 31, 2016 at 7:50 PM
    #35
    Justinlhc
    Justinlhc Not looking for a relationship
    Mine are constantly falling off. I've considered wiping some silicone on the cup before applying to help. Maybe some good double sided tape? I've been licking the cup before applying and that seems to last a while.
    Biscuits likes this.
  16. Jan 3, 2017 at 8:50 AM
    #36
    USDashCamera
    often times it depends on the quality of the suction cup. Many use really cheap rubber that is not that sticky, where as I have bought this one: https://www.amazon.com/gp/product/B0105P4FDC and it is great. the rubber actually is sticky so its like it has an added level of suction on top of the actual cup suction.
    many dash cams come with sorta cheap/low quality suction cups.
    Biscuits and dmccurdy7[QUOTED] like this.
  17. Jan 9, 2017 at 8:23 PM
    #37
    USDashCamera
  18. Jan 10, 2017 at 6:50 PM
    #38
    USDashCamera
  19. Jan 13, 2017 at 7:29 PM
    #39
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    Sub'd so I can see what I want for the front and rear dash cam setup :thumbsup:
  20. Mar 15, 2017 at 7:29 PM
    #40
    USDashCamera
    added a few new reviews to my original 2 posts, added an A119S vs A119 review, the new G1W-S, and also a budget Street Guardian model.
