Dash Cam suggestions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RedsWhiteTaco, Feb 12, 2020.
  1. Feb 12, 2020 at 6:42 AM
    johnnyroid
    johnnyroid Well-Known Member
    Vine Grove (Fort Knox) Kentucky
    2017 Black Tacoma Sport TRD
    I didn't know Toyota made a dash cam, could you provide more information?
  2. Feb 12, 2020 at 6:43 AM
    XJfella95
    XJfella95 Product Developer
    Brandon
    Reading Pennsylvania
    '08 Taco DCSB
    A Few
    Do any of you guys who have done research into dash cameras know if there's a unit out there that records its own front facing as well as rear facing that is stock on the truck from a video spitter? I have an aftermarket rearview camera installed on my truck that i use for back-up and rearview through my head-unit. THe camera is powered on through with ignition.
  3. Feb 12, 2020 at 6:44 AM
    aro
    aro Well-Known Member
    Orange County, CA
    2019 OR DCLB 4X4
  4. Feb 12, 2020 at 6:45 AM
    bonifacio
    bonifacio Well-Known Member
    Central PA
    2019 Cement Gray Tacoma OR 4x4
    I think I might go this route if I ever pick out a dash cam. Seems like the cleanest solution with adjustability.
    XJfella95 likes this.
  5. Feb 12, 2020 at 6:48 AM
    JBone25
    JBone25 Well-Known Member
    Subd because I want to see what you use to mount the Garmin to the GO PRO mount.
  6. Feb 12, 2020 at 7:01 AM
    bonifacio
    Central PA
    Might have to get a front/rear dash cam, then splice. Don't know if it will stay on or cut out when you activate the reverse.
    or just get a all in one where front/rear is built into the unit. Would see the bed and from inside the cab.
    Just ideas.
  7. Feb 12, 2020 at 7:08 AM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    I think it will be unique, and I hope it works. But I won't know for sure until the parts arrive in the next few days.
  8. Feb 12, 2020 at 7:22 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Attaching a clamp around the mirror leg is a great way to get your mirror to fall off and take a chunk of the windshield with it.
    Happened to a buddy of mine. They're really not meant to support much more weight than a standard rearview.
  9. Feb 12, 2020 at 7:38 AM
    LTG4087
    LTG4087 Well-Known Member
    LT
    DFW
    2019 TRD Off Road
    nose around at Blackboxmycar.com. They carry many brands and have good info and advice.
    Rett72 likes this.
  10. Feb 12, 2020 at 7:41 AM
    680680
    680680 Well-Known Member
    BARRIE, ONTARIO,CANADA
    20 trd pro army green
    Stock for now
    Yes toyota has one i will try and post some pics and info latter today
    johnnyroid[QUOTED] likes this.
  11. Feb 12, 2020 at 8:24 AM
    XJfella95
    Brandon
    '08 Taco DCSB
    A Few
    Ram mount makes this as well. goes between the windshield and the mirror. I wouldn't attach anything else to the mirror button if it was stock.
    https://www.rammount.com/part/RAP-B-369AU
    However, there was a fellow on here from years ago who made and sold RearView mirror risers. I used one of his risers with some 3M tape to increase the load capacity. That and the Ram mount might be an option.
    but you're still running the risk of it pulling the button from the windshield
    Edit, I will add that i have tried to Epoxied the button to the glass. I wouldn't suggest this as then you're counting on the glass being the weakest point. After doing so the glass failed and broke off about a 3" diameter section including the button.
  12. Feb 12, 2020 at 9:01 AM
    mrtonyd
    mrtonyd Well-Known Member
    Tony
    Colorado
    2019 TRD OR DCSB cement
    Where is the GoPro mount in your 2018? I have a 2019 but don't see one anywhere. I got the dmm with GoPro mount for that reason, lol
  13. Feb 12, 2020 at 9:08 AM
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    I have a 2017, but I've read on TacomaWorld that the 2019's and up no longer have the GoPro mount.
  14. Feb 12, 2020 at 9:10 AM
    mrtonyd
    Tony
    Colorado
    That would make a lot of sense. Thanks for the reply
  15. Feb 12, 2020 at 9:53 AM
    #35
    johnnyroid
    2017 Sport
  16. Feb 12, 2020 at 9:54 AM
    #36
    bonifacio
    Central PA
    Wanted a clean and simple way without stickers or suction cup. Back to brainstorming.
  17. Feb 12, 2020 at 9:55 AM
    #37
    mrtonyd
    Tony
    Colorado
    Hmm. looks like the passenger side on the windshield kinda behind the rear view mirror from the driver seat. pretty sure I don't have that.
  18. Feb 12, 2020 at 9:56 AM
    #38
    johnnyroid
    Yes, that's the location, but as somebody else here stated, believe that phased it out for the 19, and possibly the 18 as well.
  19. Feb 12, 2020 at 9:57 AM
    #39
    bonifacio
    Central PA
    Maybe I could source out just this buckle mount and find some type of clear adhesive.
  20. Feb 12, 2020 at 9:59 AM
    #40
    judgefudge72
    judgefudge72 Well-Known Member
    PNW
    CARMAX HAS MY TACO NOW
    My 18 had the gopro mount. My 20 does not.
