Dash Cam
Discussion in '1st Gen. Tacomas (1995-2004)' started by TurbulentLamp, May 30, 2019.
  1. Jul 14, 2019 at 2:30 PM
    #81
    1997tacomav6
    Denver
    I like this setup, but do they come in a split view option in this model,
    So you see both front and rear at the same time?
  2. Jul 14, 2019 at 5:16 PM
    #82
    USDashCamera
    USDashCamera Put it in H
    2017 Quicksand TRD OR
    It does but the screen is only 2 inches. But it does have an AV out port. Not sure if it would work with a factory LCD screen at all.
  3. Jul 30, 2019 at 11:04 AM
    #83
    Taco de Naranja
    Taco de Naranja Well-Known Member
    Benny
    NW WI
    2017 TRD Sport DCSBAT-Inferno
    Installed the Viofo A129 Duo dash cam. Thanks for the recommendation @USDashCamera
    Front cam view
    Rear cam view
    GQ7227 and USDashCamera like this.
  4. Aug 8, 2019 at 4:33 AM
    #84
    Planespotting
    Planespotting Well-Known Member
    Miles
    Michigan
    2019 SR5 V6 DCSB, '74 FJ40, 05 Ducati Multistrada S
    Decals!
    I just want one with front & rear HD, an easy button to record if I see something, and the ability to easily switch between cars. Park mode would be nice, but not necessary. The Tacoma is factory tint on the rear window, the Audi a bit darker. Anything fit the bill?
