Dash Cam
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 45Frank, Dec 1, 2024.
  1. Dec 29, 2024 at 4:06 PM
    #41
    OSUTacoma
    OSUTacoma Well-Known Member
    OHIO
    2023 Lunar Rock TRDSport DCSB
    I am . What did you do to solve the problem ?
  2. Dec 29, 2024 at 4:09 PM
    #42
    MITaco6MT
    MITaco6MT Member
    2023 Barcelona Red DCSB Sport 6MT
  3. Dec 30, 2024 at 6:27 PM
    #43
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    side question:
    what brand are you going with for the memory card?
  4. Dec 30, 2024 at 6:34 PM
    #44
    cedy01
    cedy01 Active Member
    Cedric
    Vancouver
    2016 Black Tacoma TRD Sport
    3" bilstein lift 33" tires SCS rims off-road lights TRD pro grille & amber lights cali raised rock slider +more to come
    Do you or anybody else know if this can be used with a splitter to power both a radar detector and a dash cam?
  5. Dec 30, 2024 at 8:09 PM
    #45
    OSUTacoma
    OHIO
    Sandisk ImageMate 64GB
  6. Dec 31, 2024 at 12:30 AM
    #46
    that180guy
    that180guy Well-Known Member
    Alex
    DCLBOF
    jebus, i have not realized the dognar adapter existed till now. i run a fuse tap with a mini 2. gonna change this up with my next paycheck.
    45Frank[OP] and Canadian Caber like this.
  7. Jan 31, 2025 at 6:18 PM
    #47
    MTBTACORN
    MTBTACORN Well-Known Member
    Ontario, Canada
    23 Tacoma TRD Pro 21 Sportster S
    Those with a Garmin Mini 2 or 3, are you using it without a subscription? If so, I’m assuming it just records to the SD card and you do not get any alerts. Can you still use Parking mode but no alerts? Is there anyway to view the videos on the Garmin app?
  8. Feb 3, 2025 at 11:20 AM
    #48
    Amocat15
    Amocat15 Well-Known Member
    Bucks County, PA
    2021 DCSB TRD OR
    I just installed a Garmin Mini3 with the Dongar adapter to the rearview mirror plug. I am still learning my way around the settings, but I did not sign up for the "Vault" subscription for online storage. My understanding is it records to the SD card continuously and overwrites as needed. You can press the save button to save a video (protects it from being overwritten I think) to the SD card in a more permanent way. Using the Garmin Drive app you can review and download the videos. According to the manual, it has sensors for detecting an "incident" and will automatically save 15 sec before and 15sec after to SD card.
    One thing I am trying to figure out is it is very slow to access the videos and download using the Drive app on my android phone. Not sure if that is normal, or something with the SD card I chose? Any other min2/3 users have this issue? The SD card is this which meets the Garmin requirements: https://www.amazon.com/dp/B09X7C7LL1?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
    Also wanted to add, not sure about parking mode. Using the power adapter connected to the rearview mirror, it is only powered when the Tacoma is on.
    MTBTACORN[QUOTED] likes this.
  9. Feb 18, 2025 at 1:27 PM
    #49
    BarefootBuilder
    BarefootBuilder Member
    Fort Collins, CO
    99' Tacoma Xtracab 4WD
    Bilstein 5100, OME 2881 coils and Wheeler's 2" AAL
    @MGMDesertTaco Any updates on the Wolfbox install and usage? I put a Ovrlnd camper with zero windows on my 1st gen and I'm looking to install a replacement mirror/camera before I finish the interior build out this spring and would love some feedback on this setup.
  10. Feb 18, 2025 at 3:01 PM
    #50
    MGMDesertTaco
    Dongar Pro will work with older Tacoma's, but the 24/7 auto record feature won't unless your truck is within the years listed on the compatibility list of the dongar pro.
    I'm still using the cigarette adapter to power it. I might hardware it if I ever get around to it. I might yank it out and put the oem mirror back in. Finding a mounting location for the rear camera was the hardest part. This post below seems to have solved that issue.
    https://www.tacomaworld.com/threads/wolfbox-experience-in-taco.825210/page-5#post-30425716
    I need to order one of these brackets...
    https://www.tacomaworld.com/threads/wolfbox-experience-in-taco.825210/page-5#post-30449993
  11. Feb 18, 2025 at 8:34 PM
    #51
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    My NextBase GW522 does not operate if the memory card *writes* slower than 50 MB/s. I am currently using a 90 MB/S SD card. If you look at the directories on that SD card you will probably find more than written video/pictures but a directory to keep status of the unit ... thus the need to write at high speeds.
  12. Feb 21, 2025 at 12:08 PM
    #52
    Wick
    Wick Active Member
    Anyone have thoughts on the Genuine Toyota Dashcam? Besides the expense of course. Seems like it's a clean plug in.
  13. Feb 21, 2025 at 2:38 PM
    #53
    MGMDesertTaco
  14. Feb 21, 2025 at 6:51 PM
    #54
    MannyS
    MannyS Well-Known Member
    Republic of Texas
    My 23 has the OEM unit installed by the distributor. 1080 resolution and no rear camera. Works ok. You will need to buy a larger mem card. Toyota app access/functionality to the camera and data files is basic.
  15. Feb 21, 2025 at 7:20 PM
    #55
    dryheat
    dryheat Well-Known Member
    Nope, they're just slow as shit and the Garmin app sucks. It's good to know it's there and in case of an accident I can pull the SD card and put it in my laptop but I'd like a dashcam that allows me to quickly and reliably transfer straight to my phone whenever I want.
  16. Mar 13, 2025 at 2:36 PM
    #56
    Age315
    Age315 Well-Known Member
    AJ
    Castle Rock, CO
    2016 BBP Yeti Mobile
    TRD Baja Kit with JBA UCA's 1/2 inch spacer on top, Medium Dakars with BAMF hangars and super bumps all around. 285/75/16 Cooper Discoverer AT3 XLT's on graphite TRD faux beadlock wheels. Pro skid powder coated black with Pelfreybilt aluminum mid skid and aluminum gas tank skid.
    Question for you, did that mount come with it or is that a different mount? They are having a 25% St Paddy's day sale and I might pick one up. How's it been holding up these last few months?
  17. Mar 13, 2025 at 2:55 PM
    #57
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    I've been using a Samsung Pro Endurance in my dash cam since 2020. Though the Sandisk extreme should be a good card too. Just look at the secs on the card be sure its rated for extreme temperatures and for security camera use. I got a cheap PNY card at Walmart when I got my dash cam and in a few months of the recordings being overwritten constantly it trashed the card and the camera would not record to it.
    https://www.amazon.com/dp/B07B984HJ5?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
  18. Mar 14, 2025 at 8:02 AM
    #58
    shaggy135
    shaggy135 Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    That is a different mount. It's the all metal one that you can get off the 'Zon. Only negative is waiting for it to arrive, ha.
    https://www.amazon.com/dp/B09CZF6L3H
  19. Mar 14, 2025 at 10:16 AM
    #59
    Age315
    AJ
    Castle Rock, CO
    I did some research and found it on ezdashcam.com too. I just thought about this but if you have a mirror with homelink you will lose that functionality by replacing the mirror or even attaching this to the mirror. I'm guessing there is no garage door functionality in the Wolfbox which kind of sucks because they are 25% off right now on their website with code LUCK25 if anyone is interested.
  20. Mar 14, 2025 at 10:29 AM
    #60
    shaggy135
    That was a feature I was ok with losing. I have a garage door remote anyway.
    Age315[QUOTED] likes this.
