Dash Camera Choices?
Discussion in 'Audio & Video' started by docsg, Feb 7, 2016.
  1. Nov 16, 2016 at 9:24 AM
    #121
    venezian
    venezian Well-Known Member
    Los Angeles
    2022 7545E
    Thank you! With your setup does the camera turn on only when the vehicle is on?
    I might need to run mine through the A pillar down into the fuse area because I use parking mode once in a while and THIS allows me to manually control power when the vehicle is off. It also turns off automatically to prevent battery discharge. The module is small enough that I can mount it near the headliner if the ports in the mirror are "always on"
    I have the SG version and i'm waiting for a dual channel to be released. There's a possibility it'll be released around the holidays...
  2. Nov 16, 2016 at 9:31 AM
    #122
    Sagebrush
    Sagebrush Well-Known Member
    Gens 1, 2, 3, and 4
    When I start the engine, it starts recording. When I turn the power off, it saves the video and then shuts down.
    It has a motion-sensor mode that I have turned off. I assume that if it were on, without the vehicles power, it would begin recording and use its capacitor to record. This almost has to be how it works or it'd just sit there and record when I had the ignition turned off. But I'm not sure.
    SB
  3. Nov 16, 2016 at 9:53 AM
    #123
    venezian
    Los Angeles
    2022 7545E
    The capacitor gives it just enough juice to "close" the video file (prevent corrupted files from unexpected shutdown) and shut down properly. The capacitor replaced small batteries in the older generation dash cams because over time they go bad considering the amount of heat/sun it's exposed so where as a capacitor will not be affected and wear down like a tiny battery.
    Looks like i'll have to run the wire down.. no biggie, it's just such a clean setup you have.
    Sagebrush[QUOTED] likes this.
  4. Dec 5, 2016 at 4:43 PM
    #124
    RIDERED67
    RIDERED67 Well-Known Member
    2017 TRD OFFROAD QUICKSAND, DCLB, TECH
  5. Dec 9, 2016 at 7:35 AM
    #125
    Nemx735
    Nemx735 Member
    Nick
    16 Tacoma TRD Sport DCSB
    Stock
    Have had my Thinkware F770 installed for a week now and its pretty awesome. i picked it up with the rear camera, and hardwire harness, and 8gb microsd card for 374 shipped.
    Its nice having the motion detecton on when its parked. also night video quality is nice and clear.
    gpb likes this.
  6. Dec 9, 2016 at 8:01 AM
    #126
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    Nice. Did you pull power from the overhead console or did you pull it from the fuse panel?
  7. Dec 9, 2016 at 8:14 AM
    #127
    Nemx735
    Nemx735 Member
    Nick
    Stock
    I used the fuse panel
    gpb likes this.
  8. Dec 12, 2016 at 3:41 PM
    #128
    gpb
    Atlanta
    Put in my order for an F770 dual today. I know how to get the A pillar trim off, need to look up how to get behind the rear trim panels.
  9. Dec 12, 2016 at 4:27 PM
    #129
    i8boots
    i8boots Well-Known Member
    UT - 801
    2017 MGM DC SB TRDOR JBL
    Hood/bed lights, pop-n-lock, RSI EvoA, fully custom fuse box, Husky mudflaps, white interior LEDs, Morimoto xB v2 Headlights, Bilstein 6112/5160, Sumo Springs, Meso puddle pods and overhead lights, anytime backup mod, light out in reverse mod, ac drain mod, Calirased CAT protectors, ARB Dual Air in bed.
    I decided to reuse my Mobius from my subaru:
    https://www.amazon.com/Mobius-Action-Camera-1080P-Sports/dp/B00DP1WYD2
    It attaches to the gopro mount with:
    clip - https://www.amazon.com/gp/product/B00FZMIJBU
    custom thumb screw - https://www.amazon.com/gp/product/B00IE3JDSU
    3D printed adapter - http://www.thingiverse.com/thing:538670
    I bought an 12v to 5v converter from Amazon that I pulled the ceiling panel out and velcroed/double sided tape to the ceiling of the truck:
    https://www.amazon.com/gp/product/B00O6R9PCC
    I ran a dedicated power line through the headliner (fish tape) then inside the pillar panel (easy remove with two bolts, zip tied to existing wiring out of the way) then fish taped down to the kick plate. From here it runs through a grommet in the firewall to the engine compartment an is then wired to a relayed fuse in my custom fuse box. It has 5v3A of power when the truck is on.
    I could totally take pictures one of these days, but I'm not opening up the panels again.
  10. Dec 12, 2016 at 4:27 PM
    #130
    Nemx735
    Nemx735 Member
    Nick
    Stock
    You don't have to remove any panels, just use a small plastic pry tool and run the wires under the headliner. Just pull weatherstrip off the top of the drivers side doors and run wire in the channel between the headliner or apiller.
  11. Dec 12, 2016 at 6:00 PM
    #131
    gpb
    Atlanta
    Yeah, I know I could do it that way, but would rather do it the way I described. :D I believe I know how to get in there now, I'll know for sure when I dig into it next week.
  12. Dec 12, 2016 at 11:54 PM
    #132
    Scarab
    Scarab Well-Known Member
    2017 White Tacoma TRD Pro
    So on the 3rd gen Tacomas, do you need to buy the mini, small or medium fuse tap kit?
  13. Dec 13, 2016 at 4:56 AM
    #133
    gpb
    Atlanta
    It uses Low-Profile Mini fuses, so you'll want whichever matches that. I'm unsure what "small" or "medium" refer to, those don't match the known automotive fuse types. https://en.wikipedia.org/wiki/Fuse_(automotive)
  14. Dec 22, 2016 at 7:04 PM
    #134
    wudbuchr
    wudbuchr Well-Known Member
    Linnie
    Lexington, TN
    2016 (7128A) BBP 4x2 - TRD Sport Access Cab
    * Clear Bra (full front) * BBP (8T0) Side Body Molding * Tinted Windows with AWS window shades * Romik Running Boards * Color matched Undercover Lux bed cap and BedRug bed liner * MobTown Locking bed storage doors, Tailgate skin and cap * Chrome Tailgate Script lettering * G-Tec Fab Door Sill Protectors and OEM Mud Guards * Fumoto Valve * ScanGauge-II * LED Interior, Stop, tail, Bed, OPT7 LED H11 low beam and fog lights * WeatherTech floor mats * Clazzio seat Covers * Removed jump-seats & rear seat-belts * Sound deadened back wall, rear posts, rear doors and front doors with a layer of RAAMmat, a layer of Ensolite, and a layer of EzCool * Insulated the roof with two layers of EzCool * GT series Image Dynamics speakers (6x9 fronts, 6.5 rears) * Audio Control DQ-61 DSP, 5-channel amplifier and sub woofer. * Redline Tuning Quick Lift Elite hood struts * Thinkware F770 (Dual) Dashcam with Cellink Battery B * Lexus SmartKey Transmitter and Emergency Key
    For those of you running dual cameras, why not fish the cables from the overhead
    console to the mid headliner light and then to the back window. The overhead
    console comes down easily with a straight downward pull, disconnect one
    connector on the driver's side and you have access to the area between the
    headliner and roof. The mid headliner light comes down the same way, providing
    an entry point for a wire fish. From there all you have to do is run straight back
    to the rear window. Excess cabling can be pulled to one of the b-pillars or c-pillars,
    which have plenty of room to accommodate the excess cabling. I am looking at
    the Thinkware F770 Dual and that is how I intend to run my cables.
  15. Dec 22, 2016 at 11:47 PM
    #135
    TSki
    TSki Well-Known Member
    Tyler
    Salmon, Idaho
    2017 Silver Sky TRD Off-Road, 4x4, DCSB MT
    https://www.tacomaworld.com/threads/my-silver-gsu-build.460083/
    That sounds like a pretty good mix. Are you buying a premade harness for wiring or building your own?
  16. Dec 23, 2016 at 3:40 AM
    #136
    gpb
    Atlanta
    On my truck there's a pesky sunroof in the way for going across the middle, and I didn't want to blindly fish anything around the side curtain airbags at the sides.
  17. Dec 23, 2016 at 7:53 AM
    #137
    wudbuchr
    Linnie
    Lexington, TN
    I guess that's the luxury of having a Limited! I just have a Sport and have already removed the
    headliner to insulate the roof (2 layers of EzCool), so I know there is plenty of room up there to
    fish wires. Playing around the air bags is not too bad if you disconnect the battery first. I will most
    likely just use the harness that comes with the cameras and store the excess cable in one of the
    after corner posts.
  18. Dec 23, 2016 at 7:54 AM
    #138
    wudbuchr
    Linnie
    Lexington, TN
    I will most likely just use the harness that comes with the cameras and store the excess cable in one of the after corner posts.
  19. Dec 23, 2016 at 8:30 AM
    #139
    gpb
    Atlanta
    *shrug* whichever works for you. I have an OR by the way.
    Anyhow, running the single wire down the C pillar and up the drivers side threshold along with the other wiring was quick and easy. Threshold panels pop right off and I was already running power down the A pillar anyway.
  20. Dec 23, 2016 at 10:29 AM
    #140
    DRJ1014
    DRJ1014 Well-Known Member
    CA
    Do you ever notice your Mobius shutting down shortly after powering up or the record lights staying solid?
    Mine is running to a USB plug to my center console arm rest, using the capacitor and 1:4 times of powering up the truck it will turn on for a few minutes then completely shut off or I will look over to see the record lights staying solid. I unplug the mini usb for 10 seconds, plug it back in and its back to normal.
    Cant figure out why
