Dash cams
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Trd_nick, Oct 9, 2018.
  1. Oct 13, 2018 at 3:37 PM
    The-Stig
    The-Stig Well-Known Member
    Kyle
    2017 TRD Off Road / Access Cab / Long Bed
    Make sure you get one that uses capacitors and not lithium ion rechargeable battery. The lithium batteries are only good for about a year, and don't work well in extreme cold. I lost crash footage because of a dead lithium battery. Now I only use dash cams with capacitors.
  2. Oct 13, 2018 at 5:45 PM
    LTG4087
    LTG4087 Well-Known Member
    LT
    DFW
    2019 TRD Off Road
    Yep that's the one. You remove the mounting sleeve that comes with the camera and clamp this one on the barrel of the unit. It will cover a couple of the lights but that's really not and issue as the little lady inside the unit will announce what mode it is in.
    There is not an adjustment as to how tight the clamp holds the camera. It might fit just fine (tight but still can be rotated and removed) or like mine it might be a tad lose. I simply put a little tape on the inside of the mount and it's perfect.
    If you get the WiFi version, the app interface will allow you to mount the camera in either direction and you can rotate the image if needed.
    ExGunner likes this.
  3. Oct 13, 2018 at 6:00 PM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    I was worried about it being a tad loose too. That’s why I put the cuts in the barrel, thinking some $0.39 O rings would provide just enough friction to hold it in place.
    Also, the updated firmware and software will now let you flip the rear AND front recording mode.
  4. Nov 10, 2018 at 9:43 PM
    Volt
    Volt Well-Known Member
    Overland Park, Kansas
    2022 SR5 4x4 Double Cab V6
    My fourth red Tacoma
    On my 2005 and 2010 Tacomas I pulled the front dome light panel and wired the dash cam directly to a wire that was hot when the truck was running. Has anyone here done this with a third gen?
  5. Nov 11, 2018 at 12:07 AM
    Volt
    This is my dashcam footage of my low speed deer hit. I was driving my 2010 Tacoma SR5 DCSB 4x4 down a side street looking for a motel at around midnight. It was right at about $8000 in damage. I traded the truck in while it was in the Toyota dealer's body shop. The dashcam I was using at the time was good in that it was simple and very small and had good video quality in the daytime. However, the nighttime video quality was quite bad and it had an internal battery that would fail in the summer heat. I had the dashcam hard wired into the wiring up in the headliner near the front dome lights. I want to do the same with my 3rd Gen. https://www.ebay.com/itm/Smallest-M...epid=2173071110&hash=item5d686c346e:rk:1:pf:0
  6. Nov 11, 2018 at 6:24 AM
    TailHook
    TailHook You just gotta keep livin' man, L-I-V-I-N
    Alan
    Southern UT
    2018 TRDOR 4X4, 2007 Sequoia 4X4
    Blueskysea B1W...I have front and rear facing cameras in both the Tacoma and 4R for the price of one Blackvue. RTFM and use the latest firmware...solid performance in all conditions.
  7. Nov 11, 2018 at 8:33 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
  8. Nov 11, 2018 at 9:20 AM
    Ceriksson
    Ceriksson Well-Known Member
    Clayton
    2017 Cement TRD Pro
    ARE Overland Cap, OEM roof rack
    I have a blackvue in my other vehicle, been going strong for over 6 years now. Replaced the micro SD now and again .
    In my Taco I have the Garmin 65w. 180 degree wide FoV which is great.
  9. Nov 11, 2018 at 11:44 AM
    Nunya Bizness
    I have a cam out of my dads old patrol vehicle. Works great. Motorola something or other.
