Dash Cracking noise
Discussion in '3rd Gen. Tacomas (2016-2023)' started by fishless, May 21, 2016.
  1. May 21, 2016 at 2:25 AM
    fishless
    fishless [OP] Active Member
    I have had a 16 trd offroad for 6 months now and I just started hearing a cracking noise from dash when driving down the road. It's not all the time but every once in a while I hear it. Anyone else had this issue?
  2. May 21, 2016 at 6:35 AM
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    There are a couple areas that have made noise a couple times for me (usually if the truck has been in the hot sun, I'm assuming the plastic expands to the point where it can rub). Either the speakers on the dash (driver or passenger side) or the panels by the side view mirrors. Try pressing on those when the noise comes up and see if it goes away.
    The hammer likes this.
  3. May 21, 2016 at 7:54 AM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    My house makes cracking noises when the temp changes at times, but as long as it goes away when acclimatized and not make itself at home, all is well!
    Cheers!
    ChadsPride likes this.
  4. May 21, 2016 at 10:47 AM
    sawed off
    sawed off Well-Known Member
    Randy
    Idaho
    Prerunner 2wd 2.7 SR5
    I have found, where I thought noises were coming from wasn't accurate at all. I thought my wifes car dash had rattle, turned out to be headliner. Point is you might not have cracking dash even though you swear it is that area.
  5. May 21, 2016 at 7:09 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    I have the same noise coming from the passenger side top dash. Really annoying when I have a long commute and want silence. Sometimes leads to me smashing the dash with my fist. I know it won't fix it, but it makes me feel better.
    Beats231, 0210 and ChadsPride like this.
  6. May 21, 2016 at 8:31 PM
    cohiker
    cohiker Well-Known Member
    2016 DCSB SW V6 4X4 Tacoma
    I had the same issue. Turned out to be something I put in the glove box and forgot about...
  7. May 22, 2016 at 12:28 AM
    saeedibijan
    saeedibijan Well-Known Member
    Bijan
    2016 MGM SR5
    Mine does the same thing, sourced it to the speaker that's on the dash on the passenger side. Almost like a buzzing noise.
    Coming up to my 5k service in a couple weeks here. Not sure if I should try fixing it myself or have them deal with it
  8. May 23, 2016 at 2:20 AM
    fishless
    It's not the speakers. It's coming from the middle of the dash, kinda behind right in line with the radio. It's not heat related either. Does it in the morning and afternoon. I took everything out of the glove box. Still doing it. Guess I will have them look at it when I take it in for the 10k service
    CanyonRunner likes this.
  9. May 23, 2016 at 11:26 AM
    CanyonRunner
    CanyonRunner 100% PENETRATION
    Pacific Northwest
    2016 TRD 4X4 DCSB
    $$$ Money Pit $$$
    Mine is coming from the exact same area, am having a hell of a time trying to track it down. Already tried the spot next to blower and dash speaker covers, mine is not coming from there. Also, have one from only the drivers window when cracked about 1-2 inches.
    Let me know if anything is found for the center of the dash one.
  10. May 23, 2016 at 12:01 PM
    stolenword
    stolenword Active Member
    Not sure if this helps but I had the exact same issue. I tried all the recommendations on the forum and my fix was to wrap the cable harness under the glove box in felt. I think the noise is coming from the electrical tape wrap material that they wrap the harness in. The sound then echoes up the dash and sounds like it is coming from the passenger speaker/dash area. Once I put felt around the harness the sounds went away (or is just being muffled by the felt).
    Your mileage may vary but for me this worked.
    tcBob likes this.
  11. May 23, 2016 at 12:03 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Mine does the same. I thought it was normal, at least that is what the service advisor told me.
  12. May 23, 2016 at 1:04 PM
    James_Bond
    James_Bond Well-Known Member
    Southern California
    '16 TRD Sport DCLB
    All stock
    there was another thread where they placed some cardboard on the side and it solved the issue. Looking for it...
  13. May 23, 2016 at 1:05 PM
    James_Bond
    Southern California
    '16 TRD Sport DCLB
    All stock
  14. May 23, 2016 at 1:05 PM
    James_Bond
    Southern California
    '16 TRD Sport DCLB
    All stock
    meant to say tooth picks lol
