Dash Illimunation Dimming Harness - Auxiliary Switches
Discussion in '3rd Gen. Tacomas (2016-2023)' started by johhen, Feb 12, 2020.
  1. Feb 12, 2020 at 12:58 PM
    johhen
    johhen [OP] Member
    With a little elbow grease, removing and rearranging pins, the following harness worked excellent in my 2020 Tacoma, connected in line with the bed-light-rocker, to tap into the illumination +/- for my auxiliary switches. For some knowledge for others, it appears the illumination + is a fixed +12v, while illumination - is a PWM controlled switch between 12V and Gnd, based on brightness (full bright is 100% ground).
    https://www.amazon.com/gp/product/B07Y2DJFXC/
    You will probably want to buy a pin removal kit, if you don't have one. The pins are hard to get out (especially the double wire ones).
    You will need to rearrange the pins (but keep them in-line in both plugs) such that the "tap" wires look as follows (top left, top right)
    If you are interested in creating your own lead from there into standard aftermarket switched (AOB, or CH4x4), rather than joining the cables, here are the parts you need to order (as well as a crimp tool).
    IL-AG5 Pins
    IL-AG5 Connector
    Boghog1 likes this.
  2. Feb 15, 2020 at 8:11 AM
    caribe makaira
    Caribbean, Puerto Rico
    Boghog1 likes this.
  3. Feb 15, 2020 at 8:15 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    I made one when meso was selling the ECT plugs for my CB radio button.
  4. Feb 15, 2020 at 8:54 AM
    caribe makaira
    Got a pic of the terminal crimp with dual wires before inserting them into the connector?
  5. Feb 15, 2020 at 8:56 AM
    5nahalf
    Erik
    Minnesota
    I dont, but I used pretty small wires, so I ended up soldering them to the terminals. I dont have a crimper, but I have a small soldering iron that I use.
  6. Feb 15, 2020 at 4:55 PM
    johhen
    johhen [OP] Member
    Thanks. If you serach for similar harnesses, there are ones that are just one side or the other (or both) for cheaper. But I was lazy. And extra $10 to _not_ have to join 6 wires.
