Dash light cause and fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dmcmillian526, Sep 9, 2025 at 5:44 AM.
  1. Sep 9, 2025 at 5:44 AM
    dmcmillian526
    dmcmillian526 [OP] New Member
    Tuesday
    Dylan
    2015 Tacoma TRD off road
    Does anyone else have this problem, if so what’s the cause and how did you fix??
    Backstory: I was driving to work yesterday morning and all four of these light just lit up randomly at once. Got to my station and cranked it up this morning and the abs, traction control off light were off but the rear lock light was still on, and was dim. Drove for about 5 minutes and the abs and traction light flashed and then stayed on. Arrived home and all lights are still on. (Rear lock is not on)
    2015 Tacoma
  2. Sep 9, 2025 at 6:03 AM
    JAGCanada
    JAGCanada Well-Known Member
    Canada
    2010 TRD Sport V6 Auto Double Cab MGM
    If the IG1 No 2 fuse on the interior fuse panel trips, similar lights light up. A blown fuse wouldn't explain the lights coming on and then going off, but maybe worth having a look at.
  3. Sep 9, 2025 at 8:11 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Is your truck 4wd or 2wd?
  4. Sep 9, 2025 at 9:44 AM
    dmcmillian526
    Tuesday
    Dylan
  5. Sep 9, 2025 at 10:03 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    On a 2wd it's possible the locker is engaged, have you tried cycling the diff lock button?
    If that doesn't work go to the rear axle and unplug the detection switch and see if the locker light goes out.
  6. Sep 10, 2025 at 4:02 AM
    dmcmillian526
    Tuesday
    Dylan
    I checked that as well to make sure I wasn’t going crazy, the rear locker is not engaged. I did unplug it yesterday and they were still there.
  7. Sep 10, 2025 at 5:36 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    So we either have a wiring issue or a module issue.
    I'd say try unplugging the 4wd ECU first and see if locker light goes out, if not unplug the ABS module and see if it goes out.
  8. Sep 10, 2025 at 5:38 AM
    dmcmillian526
    Tuesday
    Dylan
    Where is that located since mine isn’t 4wd?
  9. Sep 10, 2025 at 5:41 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
