Dash Light issue - 2007 toyota tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ToyotaLeland, Jul 2, 2017.
  1. Jul 2, 2017 at 9:46 PM
    ToyotaLeland
    ToyotaLeland [OP] New Member
    2007 toyota tacoma dclb
    Aftermarket Kenwood deck installed a while ago and everything was working fine up until yesterday when some of my speakers were not working.. so i pulled the deck out and found some loose wires. I proceeded to re do all the connections to the wires so that this wouldnt happen again. After I put the deck back in and turned the truck on the dash lights would not work when i turned my headlights on. I took everything back apart and made sure that my dimmer wire was connected properly.. It was connected (orange and white to the orange and black ?) anyways .. i tryed connecting the wire to a few different loose wires that i thought it might be but nothing seemed to work properly.. im at a loss..
  2. Jul 2, 2017 at 9:47 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    You probably shorted the dimmer switch
    I've seen 6-7 trucks have that problem after installing a new radio
    Unplug the dimmer switch and see if they turn back on (partially)
  3. Jul 2, 2017 at 9:48 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Have you checked your fuses?
  4. Jul 2, 2017 at 9:57 PM
    ToyotaLeland
    The fuses seem to be fine. Would the dimmer switch be shorted out if they still work with the running lights or ?
    The dash lights only cut out once i flick on my headlights .. anyways i will unplug my dimmer switch and see what happens?
  5. Jul 3, 2017 at 9:02 PM
    ngrunhovd
    ngrunhovd New Member
    Nick
    2008 Tacoma
    Have you had any luck fixing this? I had the same problem after installing a new radio. The a/c lights work and the dimmer switch will adjust those but I have no light in my dash. I found what looked like a burned terminal at the a/c light cluster but didn't find any blown fuses.
    I did a temporary fix with mini led lights from the cigarette lighter to behind the dash and back through the steering column but I am looking for a more permanent fix now too.
