Dash lighting messed up
Discussion in '3rd Gen. Tacomas (2016-2023)' started by scottybob6, Jan 1, 2021.
  1. Jan 1, 2021 at 10:28 AM
    scottybob6
    scottybob6 [OP] Member
    David
    2016 white Tacoma SR5 4 wheel drive
    Century topper
    Had the oil changed yesterday by a local that I've used several times. 66K m on the truck now. After starting the truck and driving a few blocks I noticed I had no Tach or Speedo light and no lights for the climate control. I went back to the shop and showed them what was going on and they had no clue. Fact is; Now when you turn on the headlights, the Tach and Speedo and Climate lights come on and the Audio dims. So the audio lighting is doing what it is supposed to but the other three pieces of the puzzle are backwards. Any ideas? Thanks guys you always been very helpful in the past.
  2. Jan 1, 2021 at 10:31 AM
    jimmerheck
    jimmerheck Well-Known Member
    Vancouver, WA
    2019 Tacoma Limited in white
    did the dash light dimmer get turned all the way down?
    shakerhood, scottybob6[OP] and Chew like this.
  3. Jan 1, 2021 at 10:33 AM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Are you saying that when you manually turn on your headlights that the tach, speedo, and climate control lights do turn on?
  4. Jan 1, 2021 at 12:25 PM
    eurowner
    eurowner Duke Sky
    Scoty
    How old is the battery? How much corrosion is on the battery cable ends?
  5. Jan 1, 2021 at 1:00 PM
    scottybob6
    David
    Century topper
    Thanks to all of you. I will check the battery cable ends for corrosion, seems likely suspect. And Duke, just moved last year from Grand Junction to Southport, NC. Sure miss the mountains but my wife can breathe a lot better here. BTW, the dash light dimmer was only affective when the headlights were on. Also, opposite of how it is supposed to work the Tach, Speedo and Climate Control are off until the headlights come on. Happy New Year,
  6. Jan 1, 2021 at 2:57 PM
    tacobelletx
    tacobelletx Well-Known Member
    TX
    '18 Sport ACLB
    Maybe I'm reading this wrong, but aren't the dash lights supposed to only come on in DRL and headlight on mode (and radio dim so it isn't blindly bright at night)? Does this function differently with auto lights or something?
  7. Jan 1, 2021 at 3:24 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Thats what it sounds like to me, he just needs to turn it back up.
    na8rboy likes this.
  8. Jan 1, 2021 at 3:38 PM
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    Probably. Had that happen on mt Tundra when the dealer reset the service indicator. Took about 3 seconds to figure it out. But I had the advantage of having already reset the indicator myself.
    shakerhood[QUOTED] likes this.
  9. Jan 2, 2021 at 5:32 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    No your right, as I am reading this his lights are working exactly how they should be. When the headlights or running lights are on, the dash lights are on, when they are off the dash lights are off... thats how tacomas work.
    shakerhood likes this.
