Dash lights - I want them on all the time
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pop-of-Spfd, Nov 20, 2023.
  1. Nov 20, 2023 at 6:23 PM
    Pop-of-Spfd
    Pop-of-Spfd [OP] Member
    Hi! Pop-of-Spfd here.
    I'm not new, but haven't been on the form for a while, and this is my first post.
    I have a 2012, and I have trouble seeing the instrument panel during the daytime.
    I want to bypass the daylight sensor with a switch to keep my dash lights on until I want them off.
    Anyone have a 2012 wiring diagram that would have the necessary information on it, or a better idea?
  2. Nov 20, 2023 at 6:37 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Are you talking about the instrument cluster backlighting?
    It is on all the time, you can change the brightnes with the dimmer wheel when the headlights are on or off.
  3. Nov 20, 2023 at 6:48 PM
    Pop-of-Spfd
    I don't know about your tuck, but when its daylight the daylight sensor shuts the dash lights off in my 2012. My eyes aren't as good as they use to be, and wearing sunglasses makes it impossible to see the dash or the radio!
    NotSoFastEddie likes this.
  4. Nov 20, 2023 at 6:51 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    What happens when you turn your headlights on?
    Do the headlights get dimmer, or brighter?
  5. Nov 20, 2023 at 6:55 PM
    Pop-of-Spfd
    I drive with my headlight on!
    Are you asking if my dash lights dim? I don't know.
  6. Nov 20, 2023 at 6:56 PM
    TnShooter
    Deogee
    STOCK
    When the headlights are off. The lights get brighter.
    I just checked mine, to make sure.
  7. Nov 20, 2023 at 6:56 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    There's no daylight sensor or automatic lights on a 2nd gen, the backlighting in the cluster should be on at all times and can be adjusted with the dimmer. It will dim somewhat when the headlights are turned on but still can be adjusted with the dimmer wheel. Not sure about the radio backlighting as mine has the touchscreen radio.
    4xdog likes this.
  8. Nov 20, 2023 at 6:57 PM
    Pop-of-Spfd
    Sorry! I do know, my dash lights are dim until the "daylight sensor" senses it dark, them the dash lights come on.
  9. Nov 20, 2023 at 7:02 PM
    Pop-of-Spfd
    You sure about the "daylight sensor"? If i cove it, it changes several things. I can't remember what right now, but it seems to!
  10. Nov 20, 2023 at 7:03 PM
    TnShooter
    Deogee
    STOCK
    Is your truck a 2012 Tacoma?
    Where is this sensor?
    Because there's never been one on a 2nd Gen Tacoma that I have ever seen. Nor on a diagram.
    4xdog and Jimmyh like this.
  11. Nov 20, 2023 at 7:04 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    If your talking about a 2012 Tacoma there is no daylight sensor from the factory, if there's one on there someone added it aftermarket.
    Jimmyh likes this.
  12. Nov 20, 2023 at 7:19 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Would really like to see a picture of said sensor.
    TnShooter likes this.
  13. Nov 22, 2023 at 7:27 PM
    Pop-of-Spfd
    I'm sure I'm wrong, or calling it by the wrong name, and maybe it's because I drive with my lights on all the time.
    I did notice when I turn my headlights off, the dash lights are a little brighter. Still not bright enough, and "yes" I know about the dash rheostat.
    So, is that it? As long as I drive with my headlights on my dash will be dimmer?
  14. Nov 22, 2023 at 7:46 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Yes when the headlights are on it's going to dim the backlighting somewhat.
    Being a 2012 it should have amber daytime running lights so there should be no need to run with headlights on.
  15. Nov 23, 2023 at 6:49 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Heck it might be time to get to the doctor and them eyeballs checked. Turning the headlights off will help but it’s not magically gonna make the cluster some super bright “oh I can see it now” .
    2015WhiteOR likes this.
  16. Nov 23, 2023 at 9:25 AM
    Waasheem
    Waasheem
    2007 xrunner
    https://www.amazon.com/gp/product/B00OAMFOF0?ie=UTF8
    Here’s a work around option. I used a similar one with a single instead of double light.
    My situation was a dash light was dead. Disassembled the dash, replaced the bulb, put it back together, it worked until I hit a bump in the road. I believe the problem was the bulb socket was worn due to the previous owner had those silly big wheels, it bounced and banged like mad. All that vibration wore out a bunch of things. I took it apart again, pulled the bulb socket tabs out a little bit. That worked a little longer but eventually went out again. Since taking the dash apart was such a pain in that car I used the clip on light. So then I could at least see the speedo in the dark.
    It’s just a usb rechargeable book light, flex neck, 3 brightness settings. Better than nothing.
  17. Nov 23, 2023 at 9:27 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I have "heard" that Unplugging the rheostat will make the dash lights full bright all the time. You just will not be able to dim them.
    Looking at the Illumination Circuit seems to confirm that thought as the rheostat shunts the illumination circuit partially to ground to dim the lights, with it removed nothing is shunted to ground and you should have full illumination.
