Dash lights not working right
Discussion in 'Technical Chat' started by Jeramy89, Nov 26, 2011.
  1. Nov 26, 2011 at 6:42 PM
    Jeramy89
    Jeramy89 [OP] Member
    Jeramy
    Mississippi
    2010 base 4x4
    I put an aftermarket radio in my 2010 taco. I also added 2 12" subs and now when I turn my headlights on my dash lights go out and all fuses are good atleast I think. The only fuse box I was able to find is under the hood. Does anyone have any ideas?
  2. Nov 26, 2011 at 6:50 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    You should also have a fuse box behind the little coin holder thing under your steering wheel. Do you have brake lights? If not then you've blown a fuse. Did you check your dimmer switch? Sounds stupid but I've done this to my self at least 10 times, checked fuses, checked them some more, checked wiring, check bulbs only to find that my switch was turned down.
  3. Nov 26, 2011 at 6:52 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    Sounds like dimmer switch is down
  4. Nov 26, 2011 at 7:07 PM
    Jeramy89
    Jeramy
    Mississippi
    2010 base 4x4
    Checked the dimmer switch its not that. I dont have brake lights so im guessing a fuse but im unable to find a blown fuse in either fuse box
  5. Nov 26, 2011 at 7:08 PM
    Blackshirts
    TX
    Stuff
    There is also one under the hood
  6. Nov 26, 2011 at 7:23 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    You may have wired up the dimmer circuit incorrectly. I've read a few threads on here where the dimmer circuit of the radio was wired into the dash light rheostat and should have actually been tied into a different circuit. Might want to look into that, because if it's wired wrong it could burn up the dash light rheostat switch.
  7. Nov 26, 2011 at 7:27 PM
    Joe D
    Joe D .
  8. Nov 26, 2011 at 7:29 PM
    NelsonTacoma
    Tucson, AZ
  9. Nov 26, 2011 at 8:55 PM
    Jeramy89
    Jeramy
    Mississippi
    2010 base 4x4
    Thanks everyone for the help. Ill check for exposed wires tomorrow
