Dash lights not working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by soljah111, Feb 9, 2011.
  1. Feb 9, 2011 at 11:26 AM
    soljah111
    soljah111 [OP] Well-Known Member
    Jon
    Denver
    11 supah white OR
    None yet
    I installed a new headunit yesterday and at first my night dash lights didn't work, then I took it apart and messed with it and my day gauge lights don't work. I checked the fuse by the driver side knee area and the fuse isn't blown. Does anyone know what it could be?
  2. Feb 9, 2011 at 1:59 PM
    soljah111
    Jon
    Denver
    11 supah white OR
    None yet
    Nope, neither of the gauge lights work, day or night
  3. Feb 9, 2011 at 2:07 PM
    cc350
    cc350 Retired Member
    Check your wiring, sounds like you didn't do something correctly.
  4. Feb 9, 2011 at 2:16 PM
    soljah111
    Jon
    Denver
    11 supah white OR
    None yet
    Yup I turned the dimmer up and down like 10 times now.
  5. Feb 9, 2011 at 9:39 PM
    soljah111
    Jon
    Denver
    11 supah white OR
    None yet
    The gauge cluster lights don't work, the airbag tpms check engine etc. work. Just the back lights don't work...
  6. Feb 9, 2011 at 9:41 PM
    01GREENTACO
    01GREENTACO Not all who wander are lost
    Germantown, TN
    01 4WD
    Lost track many, many mods ago.
    Check the back of the dimmer. If you didn't reconnect the wiring harness fully, none of it works. That's what happened with mine the first time I took my dash off.
  7. Feb 9, 2011 at 10:14 PM
    soljah111
    Jon
    Denver
    11 supah white OR
    None yet
    Back of the dimmer as in, the rotating dimmer or the illumination wire on the back of the stereo?
  8. Feb 9, 2011 at 10:17 PM
    01GREENTACO
    Germantown, TN
    01 4WD
    The rotating dimmer to the left of the steering wheel. In this pic the knob to the left of the tach
    In my 2001 you have to take off all of the dash to get to the radio and that's how it got disconnected. Not sure if this is the case for the newer models.
  9. Feb 9, 2011 at 10:40 PM
    soljah111
    Jon
    Denver
    11 supah white OR
    None yet
    I don't think that's the case, I didn't go anywhere near the dimmer switch while installing.
  10. Feb 9, 2011 at 10:41 PM
    01GREENTACO
    Germantown, TN
    01 4WD
    My apologies, ignore what I said then.
  11. Feb 10, 2011 at 11:52 AM
    soljah111
    Jon
    Denver
    11 supah white OR
    None yet
    I disconnected the illumination wire and checked all the fuses, still no lights. Please let me if you have any ideas as to what it could be... thanks
  12. Feb 22, 2011 at 12:35 PM
    soljah111
    Jon
    Denver
    11 supah white OR
    None yet
    So I bought a rheostat from the dealership that ran about 130 bucks and replaced it and everything now works. There are two clips on the rheostat, one on the top and bottom, I drilled them out so I wouldn't have to take apart the dash because I didnt have anything to slip in there. After that I unclipped it from the back, popped the new one in and everything was good.
  13. May 12, 2011 at 3:33 PM
    anthonyj326
    anthonyj326 Well-Known Member
    anthony
    Victoria, Texas
    07 taco
    Nerf bars, tbs, cai, aftermarket stereo and speakers, black bull bar, hids 10k, fogs 12k, 3 inch lift 1 inch in back, painted rims black
    hey i have the same exact problem was the rheostat hard to install???
  14. May 12, 2011 at 10:45 PM
    soljah111
    Jon
    Denver
    11 supah white OR
    None yet
    Not really, honestly what I did was buy a new rheostat from the dealership, I put two wood screws into the old rheostat (one on top and bottom where the clips are) and used the screws to pull it out. Then I unplugged the old one and put the new one in. Easy.
  15. May 12, 2011 at 10:46 PM
    soljah111
    Jon
    Denver
    11 supah white OR
    None yet
    When you get a new rheostat you'll see where the clips are. Also don't forget to pull your deck out and disconnect any orange (illumination wires).
  16. May 12, 2011 at 10:47 PM
    JayARRGHH
    JayARRGHH Well-Known Member
    Jay
    Bellingham, MA
    03 Tacoma SR5 TRD
    285/75/R16 Eldarado MTZ, Alpine CDE-102 Deck, DIY Snorkel, 2" Spacer Lift, Uniden Bearcat 880 CB, Custom over head console w/ map lights, CB Mount, and external CB speaker, 2 12" Kenwood Subwoofers, 300 Watt Alpine Amp, Alpine 3" lift 500# capacity
    that happened to me except it was a fuse in the engine bay instead of the kick panel.
