Dash Lights Out, Need Remedy
Discussion in 'Audio & Video' started by ThreeMan, Jan 6, 2010.
  1. Jan 6, 2010 at 11:21 AM
    ThreeMan
    ThreeMan [OP] Opinions Vary...
    Oswego, NY
    08 4x4 V6 TRD DCLB
    Eibach Springs with Billstien 5100's - Full Katzkin Leather - Back Flip Roll-X bed cover - Custom Projector/Dual Halo Headlights by ambiguous - Eagle Eye LED tail lights - LED Light Bar Mounted in Bumper - Wade In-channel Vent Visors - K&N Filter - 20% on the fronts - Rear AAL TSB - 4 Tie Down Mod - Pop N Lock - Running Boards - Billet Grille - Weathertech Mats - LED Map and Dome Lights - Optima Yellow Top - Redline Elite Hood Struts - Tunes: Eclipse 7100 HU - Eclipse IPC-106 Interface - Audison LRX 5.1K - Hertz Mille MLK2 Components - JL 13TW5 - JL cables and wires - Fully Deadened with SDS products - Metra dash kit - Custom Sub Box and Amp Rack - Still Under Construction.
    Here is the situation. The dash lights, speedo, tach, etc. go out when I turn the parking or head lights on. They operate properly otherwise. The clock and vent lights still operate and dim accordingly with the park and heads on or off.
    This has occured after my audio install. Before I tear the dash apart again, I wanted to know if anyone know the wire or wires that I have either missed or misconnected. I am sure I will figure it out but having a direction pointed out will only expedite the process.
    Thanks in advance Fellas,
    G
  2. Jan 6, 2010 at 12:35 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    15 Black DC OR Prerunner
    My guess would be that you connected the factory dimmer wire from the stereo harness to something wrong. I would first disconnect it from everything else and then see if things come back on.
  3. Jan 6, 2010 at 1:05 PM
    ThreeMan
    Oswego, NY
    08 4x4 V6 TRD DCLB
    Appreciate it Seth, I had the neg dimmer wire just hanging around back there. 3am installs will do that I guess. (Long story) Its all hooked up now. The dimmer doesn't seem to be dimming the gauges and deck, but hell, at least I will be able to see the gauges now.
  4. Jan 16, 2010 at 1:51 PM
    millerlight024
    millerlight024 Member
    05 off road
    Need some help guys, i have a pioneer deck installed i managed to wire it incorrectly because now my backlights don't work, any suggestions?
  5. Jan 18, 2010 at 8:00 AM
    ThreeMan
    Oswego, NY
    08 4x4 V6 TRD DCLB
    Check your ground wire for the dimmer. In fact, double check them all just to be sure. When mine went out, I missed the ground completely. I went back and fixed it. Problem solved.
  6. Jan 19, 2010 at 8:49 AM
    millerlight024
    05 off road
    no dice, double checked all the wires, now my speedometer isn't working, nor is my odometer...things could be worse, at least now i won't be hitting 100K (stuck at 99821)
  7. Jan 19, 2010 at 9:02 AM
    ThreeMan
    Oswego, NY
    08 4x4 V6 TRD DCLB
    Just thinking off hand. I am not presuming ignorance here, don't take offense, as I am just trying to help.
    Check fuses? Double check all the harnesses. Did you pull or tweak the wires that go to behind the dash console? It is very remote that you did. But, could there be a chance that you pulled some wires from a harness, or maybe to the point of breaking during your install? Other than these options, and testing all the wires with a meter, go to the shop. Maybe someone with more expertise than I will have better ideas.
    Good luck Bro, good news about he mileage though! ;)
