dash lights
Discussion in '1st Gen. Tacomas (1995-2004)' started by willys 1, Apr 9, 2011.
  1. Apr 9, 2011 at 3:23 AM
    willys 1
    willys 1 [OP] New Member
    dartmouth, ma
    tacoma
    the little lights behind the fan speed switch, and the switch that switches from defrost to floor heat. is there a way to change them, mines are out. thanks in advance.
  2. Apr 9, 2011 at 7:41 AM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    yeah, you can pull off the knobs and carefully pull that plate off. it's held in there by 2-3 clips. comes out fairly easily. there are two #74 bulbs behind it.
  3. Apr 9, 2011 at 10:33 AM
    Racerboy221
    Racerboy221 Well-Known Member
    Bill
    Litchfield Park, AZ
    Tacoma 2.4, Std cab/bed, 18"wheels,airshocks
    18" Wheels & Tires, Airshocks, CB Radio
    The bulbs are a OEM item....They come CLEAR from the dealer. The ones in your truck have a GREEN condom on them which you need to roll off the old bulb and roll back onto the new item (easy)
    I think they were about $3 each and there are two bulbs bac there.
  4. Apr 9, 2011 at 2:54 PM
    willys 1
    dartmouth, ma
    tacoma
    thanks. i was pulling on then and they wouldn't budge i didn't want to break anything ill try again thanks.
  5. Apr 10, 2011 at 12:24 PM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    Try twisting them, im not sure if its similar to the 01-04's but mine you have to twist and pull to get them out.
  6. Apr 10, 2011 at 1:30 PM
    Racerboy221
    Bill
    Litchfield Park, AZ
    96-99 1st gens behind the A/C are just designed to slide straight out. If they are twisted, they will break.
  7. Apr 10, 2011 at 5:15 PM
    scocar
    scocar Patron of the Farts
    You need to disassemble the center console, remove the temp control unit, and take the black cover off the back. The little f'ing bulbs twist in from the back, and were like $9 each from the dealer.
    Check out the pics in my photo gallery titled TempCtrl and CDashRem. I also have a picture of the bulbs w/ part number there.
  8. Apr 10, 2011 at 6:39 PM
    01Tac0ma
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    I think dis assembling the control is easy though, to me it seems that getting the cluster out will be more challenging than that was, but ive read thats its actually the other way around. 2 of the 3 bulbs on the temp control unit are non workin in my truck but all bulbs are good, just 2 of them dont make good contact and if you get them on they cut off with the slightest bump.
  9. Apr 11, 2011 at 5:46 PM
    willys 1
    dartmouth, ma
    tacoma
    01tac those pictures rely help going to do it tomorrow ill make sure the dealer has them. thanks again
