Dash - lite issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bluefin, Apr 3, 2009.
  1. Apr 3, 2009 at 6:28 PM
    Bluefin
    Bluefin [OP] New Member
    Hello fellow members,
    Got a 09 pre-runner Sr5 access cab,
    Had a new radio installed by dealer today, under warranty. Seems ok now, original radio would intermittenly turn on/off, a known problem with the stock tacoma radios, anyway they installed a new one right away.
    I took notice of all my other dash-lites tonite and noticed that the power window module/switch, which is mounted on the left side of lower dash was not illuminated, I never took notice of this before, I'm wondering is it suppose to illuminate or did toyota overlook this switch for illumination? Anyone else notice this or know what the deal is here?
    Any help here very much appreciated!
    Thanks
    Bluefin
  2. Apr 3, 2009 at 6:40 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    hit close to it it may come back on if its a bulb thats going out like mine
  3. Apr 3, 2009 at 6:41 PM
    AK27
    AK27 Well-Known Member
    its an 09...thats led not a normal bulb right?
  4. Apr 3, 2009 at 7:20 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    not sure im used to dealin with 1st gens, if its just a bulb goin out got to an auto store and ask, youll hafta take out the dash to get to the bulb so i reccomend findin online what kind it it
  5. Apr 3, 2009 at 7:33 PM
    Okkine
    Okkine Well-Known Member
    Vancouver, BC
    2009 Magnetic Grey Access Cab - 2.7L I4 - 4x2
    I didn't even know that there was a power window light... though you Americans have a few things we don't
  6. Apr 3, 2009 at 7:43 PM
    JAG
    JAG Well-Known Member
    What prob happened is that when they went to uninstall the radio they have to disconnect several wire harnesses in diff areas (i.e. ac controls, radio. etc.) and if someone was to pull on the wires to remove that plug, the wires would possibly pull out plug. It sounds like you have a mistake made by the tech. I would leave the truck as it is...do not try to fix it yourself because they will have to see that the lights do no actually work. They should cover it under warranty and you might have to have a little electrical work under warranty.
    If you do want to try and fix it yourself...just try giving the faceplate of the ac controls a couple taps in diff areas. I took out my radio and learned the hard way, and I was being as careful as poss with those plugs!
