dash parking brake/abs light on - help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomabuddha, Jun 6, 2010.
  1. Jun 6, 2010 at 4:13 PM
    tacomabuddha
    tacomabuddha [OP] BUDDHApower
    SoCAL
    05 Prerunner TRD
    I have a manual '05 tacoma. My dash parking brake/abs light is on even when I release the parking brakes. Everything works fine but the light is on...Does anyone know how to get rid of it? It bugs the hell out of me..can I remove the fuse? Can I disassemble the dash and pull the bulb or plug somewhere...any tips or comment is appreciated! Thanks
  2. Jun 6, 2010 at 5:32 PM
    tacomabuddha
    SoCAL
    05 Prerunner TRD
    bump anybody?
  3. Jun 6, 2010 at 5:50 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    check your wheel speed sensors. or could be a malfunction in ABS system. Read yer owners manual too.
  4. Mar 17, 2011 at 9:27 AM
    pauled71
    pauled71 Member
    Ontario Canada
    4x4 sport
    Hey just wondering if you ever fixed the problem with the abs dash lights. I'm experiencing the same problem with my 08 Tacoma now.
    Any help would be really appreciated
    Thanks
    Paul.
  5. Apr 11, 2011 at 4:52 PM
    RYOTA RACOMA
    RYOTA RACOMA New Member
    New Mexico
    05 Toyota Tacoma TRD Sport lifted
    alloy eagle rims pro comp 6" lift JL audio sub woofer K&N intake
    There is a button under the steering wheel by the gas pedal, it needs to be depressed to turn off which will then turn off light on the dash, it may not be depresses use duck tape to keep it down
  6. Apr 11, 2011 at 8:07 PM
    Tacozoid
    Tacozoid Well-Known Member
    Terry
    Katy Texas
    White Tacoma Pre-runner
    Billsteins,Texas tint. Blue Dash mod. Console mod. in Blue, Customized grille
    Now that's funny, I don't care who you are THAT'S FUNNY! It's for the tire pressure sensors. That's all it's for.
    I got tired of my parking brake/ABS lights on. I checked the fluid level, replaced Both rear sensors, replaced the harness. Finally I yanked the LED's out of the dash. Screw it. I don't have anti lock though.
  7. Apr 11, 2011 at 8:12 PM
    sambojee
    sambojee Well-Known Member
    Sam
    Iowa
    2011 TRD OffRoad
    Bilstein 5100 all around set at 2.5. 1.5 AAL in the rear. 265/75/16 Hancook Dynapro MTs on Black Moto Metal 951s. Black badges. Aftermarket grill. TRD seat covers.
    had this same problem with my 99 tacoma and the parking break light would always stay on. try pushing in the handbrake really hard (dont break anything) or twist is and let it slam in by itself (sorry hard to explain it).
  8. Apr 11, 2011 at 10:13 PM
    RYOTA RACOMA
    New Mexico
    Well when i press this button which is behind the parking Brake the light in the dash turns off haha it might not be stock
  9. Aug 4, 2011 at 2:13 PM
    toyoTRDtaco
    toyoTRDtaco Well-Known Member
    NB, Canada
    2006 Double Cab TRD Sport
    What light behind the parking brake? Pic?
  10. Aug 4, 2011 at 2:18 PM
    manofsteel
    manofsteel Active Member
    Texas
    TRD Off Road
    Not sure if same problem, but on my 11' my parking brake light was also staying on, so I took it to dealership (warranty) and they ended up replacing master cylinder and brake booster. Master cylinder was leaking into brake booster.
    Not sure if you have same problem.
  11. Aug 4, 2011 at 3:11 PM
    fbconvert
    fbconvert Well-Known Member
    Brian
    Seacoast, NH
    2005 Tacoma Double Cab TRD Sport
    I had a the same problem in my first gen. I had a slave cylinder that went out on the passenger side. I refilled the reservoir. It didn't happen right away but the light turned off and never came pack. I meant to replace the slave cylinder but I sold it before I got around to it.
  12. Jul 13, 2013 at 1:04 AM
    TacomaRed
    TacomaRed New Member
    TacomaRed
    California
    Tacoma
    Hi Everyone, We've got a 2004 Tacoma truck and are now having the same problem. The brake light on the dash is ON even though the brake is off. Agree with the person who said it is real annoying.
    So, what is the solution?
    1. Depress the button near the brake and hold down with duck tape if necessary?
    2. Check the brake fluid?
    3. Master Cylinder (Ouch - sounds expensive)
    Would love it if someone could post an update. Does Toyota ever post in these forums??
    Many Thanks, TacomaRed
  13. Jan 24, 2014 at 6:24 AM
    micgriz
    micgriz Well-Known Member
    mike
    ohio
    09 white access 4x4
    I have the same issue on my 09 tacoma. Thought maybe it had to do with automatic start I had installed. According to installer, stated it was an issue with Toyota and Hondas. Mentioned a switch behind brake peddle not depressed all the way and maybe a low battery charge. Curious if anyone else has same issue.
  14. Apr 28, 2016 at 8:50 AM
    toyotatrouble
    toyotatrouble New Member
    I also have the ABS light on..had it fixed but was said the gear is stripped inside the back... and its a very costly job...more then my truck is now worth. Abs light on is OK for inspection in my state. The problem is that the red brake is on also and that wont pass me ...I am not a mechanic ..I have tried looking at the fuze box but no luck....any ideas would be a great help. My Tocoma is 2005...or anyone in Virginia that can help..?
  15. Mar 12, 2017 at 5:46 PM
    DLACE64
    DLACE64 New Member
    SAN DIEGO
    2005 BLACK PEARL XRUNNER
    ALL INTERIOR AND EXTERIOR LIGHTING. ANY TIME FOG. PIONEER DASH 3600, LED GLOW
    Did anyone ever find out an sulution to this ABS/Ebrake lights being on??? I've had this problem for about 4 years. I've gotten used to it being on, however i still wonder how to fix this? I have changed the sensor and everything but its not working. I have looked for that button underneat the steering wheel by the gas pedal but it does not do anything... If you have found a sulution please share the info. Thanks.
