Dash raddles
Discussion in '1st Gen. Tacomas (1995-2004)' started by Browning18, Nov 13, 2016.
  1. Nov 13, 2016 at 12:56 PM
    Browning18
    Browning18 [OP] Active Member
    2003 Black Tacoma
    True dual straight pipes. Custom off road bumpers. Led strobe blue interior lights.
    I have a problem with my dash making all kinds of weird sounds by raddling on bumpy roads and when sitting at stops signs cause my exhaust shakes my truck. Any idea on how to fix it?
  2. Nov 13, 2016 at 1:28 PM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    Look up under the dash if its not in the middle and look for loose things. If it is in the middle pull the radio out and look back in there with a light
  3. Nov 13, 2016 at 2:40 PM
    1981ferrari
    1981ferrari Well-Known Member
    Brian
    2002 Toyota Prerunner
    Stock
    Welcome to a very common, annoying problem. As a fellow member told me / push down on the drivers front of passengers airbag and I bet it stops
    So what do you do? Someone said push down on it and add gorilla glue / didn't work . Can anyone help baca use I'm dying to fix it
  4. Nov 13, 2016 at 5:39 PM
    wamego
    wamego Well-Known Member
    2002 Tacoma 2x4 TRD SR5
    My passenger bag did that. Sprayed some heavey duty silicon around all the gaps on the dash, and puff, not more squeeks. Worked on my 02.
    Like above I would check everything you can get a wrench on under the dash. Hard saying what the previous owner did.
  5. Nov 14, 2016 at 8:30 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    There is a host of threads on this problem. Perhaps you could...... do a search?
  6. Nov 14, 2016 at 8:57 AM
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
  7. Nov 14, 2016 at 8:59 AM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    The dash in front of passenger side makes a loud rattle noise in my truck when its very cold. I just turn up the AM radio
  8. Nov 15, 2016 at 8:43 AM
    skeezix
    Colorado
    1998 Limited
    When I take the truck out I live with my dash rattle for the first 150 miles. By that time I'm on dirt roads and I can't hear it. When I get back on the pavement the truck sounds really quiet! :bananadance:
    But the rattle is still there.
  9. Nov 15, 2016 at 8:47 AM
    NCJeyota
    NCJeyota Well-Known Member
    Raleigh,NC
    2002 Tacoma 3.4 v6 Prerunner
    My 02 Tacoma did it only when someone was sitting in the passenger seat. I cut a strip of dense foam material about 1" by 4 " and stuck it between the dash and windshield in front of the passenger seat. I haven't heard the rattle since.
