dash rattle after intake install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SkimSTI, Sep 25, 2014.
  1. Sep 25, 2014 at 8:09 AM
    SkimSTI
    SkimSTI [OP] Well-Known Member
    Orange County CA
    '14 MGM TRD dblcab & '16 Mercedes C450
    Magnaflow exhaust, AFE stage 2 intake, King 2.5" resi coilover/rear shocks, Pro Comp UCA's, Deaver 1.5" leaf pack, BPF raptor style grill
    sup guys,
    this is a little weird. but i wanted to see if anyone is having this problem. i installed the AFE stage 2 intake a couple of days ago, and i noticed when you run it up hard (to the higher rpms where the sound boosts in..mmm) my entire dash vibrates likes crazy with the added noise!
    it only seems to happen when the windows are closed. i know these tacomas have super great seals, similarly, the doors not closing all the way unless you use a lot of force (compared to my other cars).
    so figuring this, when driving with the windows down, there seems to be no rattle in the dash. so clearly its not the intake itself. i made sure everything was tight, but man, the dash rattle is annoying as **** when i step on the gas. cant seem to pinpoint where its coming from. either top of the dash or behind the headunit.
    anyone else experiencing this? is there a fix? a fix would be nice..... but im not new to rattles. my subaru sti had about 7 rattles from the factory and now with all the mods the whole thing makes weird noise. lol
    -Skim
  2. Sep 25, 2014 at 8:28 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    Probably rattles from all that horse power gain!!
  3. Sep 25, 2014 at 8:31 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Some thing touching the fire wall hose etc.
  4. Sep 25, 2014 at 8:34 AM
    Burnt C6
    Burnt C6 Well-Known Member
    David
    Houston Texas
    Silver & Black 06 PreRunner
    Bilstein 5100 up front new Powder coated Coil Springs and Calipers, With 5160 in back, New 3” Dakar Rear Spring pack, Slotted and Cross Drilled Rotors, SS brake lines,Icon UCA’S . PIAA Driving Lights, Wheels Pro Comp 7031 17”x9 with 295/70 R70 XTreme tires. Katzkin Premium Leather Seats, Doug Thorley long tube headers and Y pipe, Under hood LED light kit,
    :burnrubber:
  5. Sep 25, 2014 at 8:55 AM
    SkimSTI
    Orange County CA
    if something like this were the case, wouldn't it make noise at all RPMs? :confused:
    just weird that when the intake noise kicks in, thats where the problem starts.. so im talkin, full throttle, over 4k rpm
    :D:mad:
  6. Sep 25, 2014 at 9:00 AM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    Mine rattles after I drive my Taco like a racecar. The filter itself gets loose, from hitting the heatshield, and it just becomes loose and rests on the heatshield. Usually when some I4 wants to race:burnrubber:
  7. Sep 25, 2014 at 9:09 AM
    medic2230
    Murph
    Bama! Roll Tide
    Harmonic vibration from the mad amounts of intake air.
  8. Sep 25, 2014 at 9:11 AM
    SkimSTI
    Orange County CA
    so basically what im getting from this, is...
    "deal with it" haha.
  9. Sep 25, 2014 at 9:12 AM
    medic2230
    Murph
    Bama! Roll Tide
    Or put your stock CAI back on and not deal with it. :cool:
  10. Sep 25, 2014 at 9:32 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    To start with, it's not normal, but definitely sounds like a harmonic is vibrating the dash. I would first check that all the tube connections are solid, that the box is definitely tight down to the fender, and that the fender intake tube has the seal installed well, and that the inlet is not hitting the fender wall. Any of these could cause a vibration that turns into a dash harmonic.
    Also, since you have the 14 with all the added emissions stuff close to the box/tube, check that there isn't anything touching. Keep in mind that as the engine revs, it moves some, so if something is close, it may well be touching at certain rpm/power levels.
  11. Sep 25, 2014 at 9:37 AM
    SkimSTI
    Orange County CA
    Thanks! :)
  12. Sep 25, 2014 at 9:40 AM
    Aw9d
    Aw9d That one guy
    I've seen this and what fixed it was to put rubber washers where the intake mounts to the metal under the hood. Someone had the K&N that did this under WOT and we added the rubber washers and that resolved the issue. Good luck!
  13. Sep 25, 2014 at 9:50 AM
    SkimSTI
    Orange County CA
    but but but... it sounds sooo throaty now! (when mated with my flowmaster)
    i'll tinker with it this weekend. Thanks all!
  14. Sep 25, 2014 at 9:55 AM
    User Name01
    Bolbi Stroganovsky
    This is what happens to mine, but to the cone filter and the plastic coupling. Especialy with the engine torquing at WOT....... I should stop doing that.
  15. Sep 25, 2014 at 2:02 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Just a thought .... Try changing the tranny mount with a non OEM block. It may change the harmonics needed to cause then issue - or hopefully fix it ....
