Dash Trim
Discussion in 'Product Reviews' started by Kevinztaco, Dec 15, 2012.
  1. Dec 15, 2012 at 6:24 AM
    Kevinztaco
    Kevinztaco [OP] Well-Known Member
    none yet
    I decided to order a dash trim kit for my Taco knowing I'll be spending quite a lot of time in my new Taco. Might as well roll like i'm in a high end set of wheels :). Pro: Looks good. Cons: The adhesive tapes seem a little thick and edges of trims are sticking out. I used a heat gun to slightly head it and pressed in firmly until the adhesive tap thin out but the edges are still there. This is not a perfect pre-cut for the taco by any means but who expects a perfect match afte-market kit, right? I didn't. It's a little pricey for a not so perfect dash trim kit.
  2. Dec 15, 2012 at 8:20 AM
    Swordknives
    Swordknives mmm Tacos
    South OC CA
    2013 Dbl cab LB v6 SR5
    Not my cup of tea. cool you found something you like that is not common on the taco.
  3. Dec 15, 2012 at 10:54 AM
    2chains
    2chains Well-Known Member
    Calgary, Alberta
    2010 Tacoma DC LB 3" Revtek lift
    3" Revtek lift, k&n 63-9025 intake, tailgate debadge, OEM Bed mat, decals gone. helo black max 6 bs 4.5 os-12,duratrac 285 70 17,smittybilt light bar, kc slimlites, pioneer pb3300 bt, window tint, weathertech digfits, raider lorider elite tonneau, at2525xl,
    thanks for posting, don't see many pics of these
  4. Dec 15, 2012 at 11:04 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I've got a carbon fiber kit. Similar experience with fit & finish.
    If I knew then what i know now I would have spent the $ elsewhere...:eek:
