Dash Vent Blocked???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Trip, Oct 14, 2008.
  1. Oct 14, 2008 at 11:42 AM
    Trip
    Trip [OP] Member
    Pembroke, MA
    2005 Tacoma Double Cab SR5 TRD Sport 4x4 LB
    ICON DR Coil Overs Ride Rite Air Bags A.R.E LSII Hard Tonneau Hella Rallye Xenon HIDs ARB On Board Compressor
    Hello all! New to this forum as I just bought my 2005 Tacoma Double Cab and I have been going over it and getting familiar. In the process I have discovered that the center left hand (or Drivers Right Hand) dash vent is literally blocked or at least passes almost NO air through it even with the Fan in the HI position. It also is regardless of the fresh air being open or closed and it is consistent regardless of the setting for the air. (ie Floor, Dash, Defog etc.) Obviously it is either blocked or the duct is disconnected to it. I have looked all over the forum and see nothing of this nature and was hoping that someone might have experienced this and fixed it and could give some advice. If that is not the case then an idea of attacking this by opening the dash might be helpful. Any and all help appreciated in advance!
    Trip
  2. Oct 14, 2008 at 11:44 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    check the cabin filter first.......your truck may have one. if so...its located behind the glove box. easy to get to........05 tacomas didnt come with the filters, but someone may have installed on there.
  3. Oct 14, 2008 at 1:14 PM
    Trip
    Trip [OP] Member
    Pembroke, MA
    Good advice. I did change the cabin filter however and one was there already. It is obviously built for one and I did see that there was no part # for one when I bought the replacement. That being said, the three other dash vents blow very strong and the LH middle has virtually nothing coming out. I am going to install a USA SPEC Ipod Interface in a few days and am hoping that the acess provided by having the radio out will give me some info as to what is the issue. I believe your idea is good but I don't see that it would block one vent but would probably block all of them...Keep it coming,
    Trip
  4. Oct 14, 2008 at 1:24 PM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    Obvious question here, but do you have the vent closed? Move the thing at the base of the vent and see if it's open or closed. (circled in red below)
  5. Oct 14, 2008 at 1:24 PM
    lsocoee
    lsocoee My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    Sometimes people melt the ducts behind the dash to install those big fancy radios. That could have happened to you. I haven't heard that this is necessary or even possible in Tacomas, but it might be. Could it also be that someone stuck a few pine tree fresheners in the vent and then they fell down into the abyss to block the air.
    What happens if you close the other vents and leave the blocked one open?
  6. Oct 14, 2008 at 1:25 PM
    mjp2
    NJ
    Shoot. That just directs the airflow, doesn't it? Damnit. I need to get my truck back on the road. It's been so long that I forget how it works! :mad:
    You'll learn quickly to ignore my posts.
  7. Oct 14, 2008 at 1:35 PM
    Trip
    Trip [OP] Member
    Pembroke, MA
    You guys are thinking for sure. As noted the vents are "open," so to speak and closing the rest does barely help get a little more out of the vent itself, but it acts as if it has something blocking it from inside. I guess I need to know how to get it apart??? Sucks! I like the idea about the air fresheners. That souds very possible. I have half a mind to get a fish tape and go fishing to see if I get joy. Keep it coming,
    Trip
  8. Oct 14, 2008 at 1:36 PM
    Trip
    Trip [OP] Member
    Pembroke, MA
  9. Oct 14, 2008 at 1:58 PM
    lsocoee
    Hotdog
    Wet Okole Underwear
  10. Oct 14, 2008 at 2:14 PM
    mws4ua
    mws4ua I'll try being nicer if you try being smarter.
    Birmingham
    2018 GMC Sierra SLT Z71 4x4... Yeah yeah, I know.
    Nobody's posted it yet, so here is how to remove the radio so you can see what's going on behind...
    Pretty fierce looking truck, btw.
  11. Oct 14, 2008 at 2:18 PM
    lsocoee
    Hotdog
    Wet Okole Underwear
    looking at the mods on the truck, I bet the previous owner had upgraded the stereo.
  12. Oct 14, 2008 at 4:10 PM
    Trip
    Trip [OP] Member
    Pembroke, MA
    Thanks for the compliment. I agree that we have no idea what the guy before me had in it as obviously the is a ton of stuff done to it. Thanks for all of the help including the dash removal post!!!
    Trip
