Dashboard and Tail lights out
Discussion in '1st Gen. Tacomas (1995-2004)' started by antz92, Jun 28, 2010.
  1. Jun 28, 2010 at 6:28 PM
    antz92
    antz92 [OP] New Member
    02 Tacoma Reg. Cab
    I just bought a used 02 Tacoma and the lights that illuminate the dashboard and the parking lights are out. Everything worked fine when I bought it, I only replaced the factory radio and one bulb for a burned out parking light. Now the're all out. I checked and replaced the fuse for the tail and it blew again. Does this have anything to do with the factory radio being removed? Any ideas?
    Thanks.
  2. Jun 28, 2010 at 6:35 PM
    SupraT
    SupraT Tacoma Lover
    Tony
    Columbia Falls
    98 TRD SR5 4x4
    3" Lift Three leaf add and Bilstin 5100"s in back and Donahoe coilovers in front, Tinted Windows, Blackened parking light, tinted brake lights, clear bumper lights, Blacked out turn signals, AVS vent visors, Electric Fan mod, K&N CAI
    My light did that when I first got it and it ended up being my trailer wiring, does it happen to be grounding out anywhere?
  3. Jun 28, 2010 at 6:38 PM
    bama trd
    bama trd Well-Known Member
    Alabama
    2007 Silver Tacoma TRD Off Road
    Painted Grill with painted Land Cruiser emblem,Tinted Windows, BF Goodrich AT 275/70/17's on 4 Runner SR5 Rims, Bilstein 5100 front and Rear, debadged, fog light on anytime mod,
    did you use the factory harness and just plug in the after-market stereo? or cut the wires and hook up the hot , ground ,and speaker wires? If you cut them ( like I've always done in my vehicles) then go back and check , sounds like you have a hot wire touching something - to keep blowing the fuse , if you unhook the radio and turn your lights on with a good fuse installed , I bet they will work. This will tell you if its the wiring
  4. Jun 28, 2010 at 6:58 PM
    03redtaco
    03redtaco Well-Known Member
    Richard
    Myrtle Beach SC/ Starke FL
    03 Tacoma Prerunner SR5 DC 3.4L
    DId you check the fuses under the hood? Mine did that a while back and I think that i replaced a fuse under the hood. Keep us posted.
  5. Jun 28, 2010 at 7:12 PM
    antz92
    02 Tacoma Reg. Cab
    I went to Kragen and got a brand new fuse rather than using the replacement under the hood and it seems to be working fine now. Thanks for the tips.
