Dashboard Rattle
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bs 02 Taco, Oct 31, 2008.
  1. Oct 31, 2008 at 1:07 PM
    Bs 02 Taco
    Bs 02 Taco [OP] Well-Known Member
    Amelia, Ohio
    02 Tacoma 4x4 regular cab 5 speed
    Swiss cap Deckplate Stupid door chime Synthetics AFE pro dry JVC Ipod compatible head unit Vanilla air freshener :) 25%tint
    Does anyone know how to fix a dash rattle by the defrost vents?
  2. Oct 31, 2008 at 1:13 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    double sided sticky tape?
  3. Oct 31, 2008 at 1:16 PM
    Bs 02 Taco
    Amelia, Ohio
    How in the world would I get it in there?
    Is it a big deal if I dropped something in the vents already? :confused:
  4. Oct 31, 2008 at 1:17 PM
    SocalMan22
    Steve-0
    So*Cal
    What Mods!
    you got me man was just a suggestion
  5. Oct 31, 2008 at 1:20 PM
    Bs 02 Taco
    Amelia, Ohio
    Well thanks for the pointer
  6. Oct 31, 2008 at 2:12 PM
    monoman
    monoman Time to get dirty!
    Dave
    Exotic, San Jose, Cal.
    2018 Silver Sky Tacoma SR Access Cab 4X4
    SnugTop SuperSport shell CaliRaisedLED light bar BFG K02 AT’s RCI skid Bilstein 5100's up front, (#2) & 4600 in rear N-2 Designs remote start/keyless entry Anytime 12v outlets... one by shifter & one in bed Daily driver....
    I had the same problem a couple of years ago. I took a 2" piece of rubber tubing (3/8 size) & jammed it in between the dash & the windshield. I Haven't had a problem since. It's a big problem with these trucks, everyone seems to have an issue with it.:rolleyes:
  7. Nov 1, 2008 at 9:18 AM
    Bs 02 Taco
    Amelia, Ohio
    I was thinking to do the same thing for the fix!!!
    Can you see it through the windshield?
    Thanks a lot for your suggestion
  8. Nov 2, 2008 at 7:37 PM
    Mr.Fahrenheit
    Mr.Fahrenheit Dennis = sinneD
    American Canyon, California
    01 Taco 3.4L 5spd TRD
    K&N CAI, HUSKY LINERS, LOW PRO TOOL BOX, GRAY WIRE MOD, OPTIMA RED TOP, GOODRIDGE STEEL BRAKE LINES, FAB TECH LIFT,
    im lazy, my fix was turning up my stereo.........:)
  9. Nov 2, 2008 at 7:40 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    mine too...my rattle is coming from the passenger airbag...but its whatever...just crank up the tunes or roll down the windows
  10. Nov 3, 2008 at 10:41 AM
    monoman
    Dave
    You can a little, but if you stuff it in there nice and even, it should look ok.....
  11. Nov 3, 2008 at 10:44 AM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Here is the TSB for this issue.
  12. Apr 4, 2010 at 10:36 AM
    01dubb
    01dubb New Member
    Brian
    Chicago
    01 prerunner
    Chrome Step rails, 800 watt 8 inch pioneer subwoofer, 800watt pioneer mono amp, Kenwood 7inch dvd Navigation,
    The dealership will just stuff foam in there to stop the rattle. It was a major problem on the 1st gen tacomas.
  13. Apr 4, 2010 at 4:05 PM
    2004Taco
    2004Taco Financially Irresponsible
    Lou
    California
    04 Double Cab PreRunner SR5 TRD
    Yea, mine rattles where the Pass. airbag is at. Any ideas for that?
  14. Apr 5, 2010 at 7:52 AM
    IamTacO
    IamTacO red balls got me!
    adam
    QC az
    01 Prerunner SR5 TRD-Offroad
    4x2 Prerunner. Hankook Dynapro ATM rf10 265-65-16, e-locker FTW! Morimoto d2s bi-xenon HID projectors, Philips 85122+ 4300K, Cobra 75 w/ 3' firefly, Kenwood KDC-MP342U w/ SIRIUS, Line-x bed liner, 4' coretrax(black)
    i did a quick fix on mine the other day. i seems like its rattling against the windshield. i'm sure thats not true, but i stuck some foam in between the glass and the dash and its about 95% quieter. you can barely hear anything now! :D
  15. Apr 5, 2010 at 8:01 AM
    crimsonred2004
    crimsonred2004 X-wing Design Engineer
    Bob'O'
    MI
    02 Limited TRD Xtracab V6 4X4
    Had the problem....went to Lowes and bought this foam insulation caulk where they sell all the weatherstriping. It comes in coils of @20'. It comes in different diameters..i got the 5/8" dia and stuffed 2 rows of it all along the dash except where the VIN is....rattle totally gone for less than $5 and 20 minutes.:D
  16. Apr 5, 2010 at 5:35 PM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    Ha, I thought mine was the only one that did this. Mine will do it once every 100 miles or so all of a sudden when I'm driving. I'll tap/press on the vent a couple of times on the passenger side where it's comming from and it'll go away for another hundred or so.
    I'm gonna put some foam in there as someone else suggested, and I'm sure that'll make it stop.:cool:
  17. Feb 12, 2011 at 7:37 PM
    rockinsteve
    rockinsteve New Member
    02 Tacoma 4cyl 4X4
    Hey, I know this post has been quiet for a while, but I just thought I would share how I fixed the passenger airbag rattle on my truck:
    Step 1: Remove glove box & plastic cover which covers airbag assy. (If you don't know what I'm talking about, see the pages in the factory manual that the pdf file posted above talks about.)
    Step 2: Loosen the two airbag bolts (the really obvious ones that are holding the airbag in place.) (Don't worry about anything falling on you when you loosen those two bolts, there are two more which will hold the airbag in place while you're working.)
    Step 3: Use some kind of pry bar (I used a really big screwdriver) to pry the airbag towards the center of the vehicle. While you're doing that, use your other hand to tighten the airbag bolts back with a ratchet/wrench.
    Step 4: Bang on the dash and make sure you don't have a rattle anymore. (If it is still rattling, try repeating step 3 again.)
    Step 5: Put everything back together
    Step 6: :), because your annoying dash rattle is now gone.
    Estimated Time: 30 minutes max
    Difficulty: Pretty easy
    NOTE: This is ONLY for a dash rattle caused by the airbag. If you have one of the other rattles described in that PDF file above, you will have to do something different.
    So get off the couch and do this fix already. Redneck remedies like putting weatherstripping on your dash are silly. This is seriously really easy.
    Good Luck,
  18. Feb 12, 2011 at 8:39 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Mine rattled, then I took duct tape and folded into into a rectangle and stuffed it in between the windshield and the dash. my problem was solved :D
  19. Feb 13, 2011 at 9:36 AM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    yup i folded a piece of paper and stuck it between the windshield and dash.
  20. Feb 20, 2011 at 4:10 PM
    Jdaniel1274
    Jdaniel1274 Well-Known Member
    Daniel
    Orange County, Ca
    01 DC TRD 4X4
    PIAA lights, OMD leaf spring mod, magna flow muffler, oil filter relocation kit
    Thank you Steve!
