dashboard rattle
Discussion in '1st Gen. Tacomas (1995-2004)' started by kevind_, Feb 1, 2009.
  1. Feb 1, 2009 at 3:42 PM
    kevind_
    kevind_ [OP] New Member
    96 Tacoma SR5
    got a 96 taco and ive got a rattling/vibrating sound coming from pretty much dead centre of the dash board above the vents. just curious if anyone else has had this problem before and has a resolution. im pretty sure its just something loose but id like to get ur guys input before i get in there. thanks
  2. Feb 1, 2009 at 4:18 PM
    brianr
    brianr go shit in your hat
    2010 4x4
    BUILT, not bought...
    I've heard of some guys using expansion foam in some places to silence the rattling.
    Luckily, my dash does not make a sound.
  3. Feb 1, 2009 at 4:55 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    mine rattles too it drives me nuts but will eventually stop
  4. Feb 2, 2009 at 7:34 AM
    shepnuts
    shepnuts Member
    thats what i did on my 01
  5. Feb 2, 2009 at 8:15 AM
    cadman
    cadman Well-Known Member
    Pensacola, Florida
    TRD PreRunner
  6. Feb 2, 2009 at 12:33 PM
    96Tacoma4x4
    96Tacoma4x4 Well-Known Member
    Memphis, TN
    96 xcab 4x4 LX stock
    32x11.50 and K&N filter drop in
    I had that crappy dash rattle, drove me up the wall. Mine was coming from the driver side, but this could your problem too. What I found out was that a screw which holds the dash in place was coming loose from the reinforcement bar inside the dash. There are two screws holding the dash on the metal bar (keep in mind driver side) right behind the instrument cluster. So the only way to get to those is take the cluster out, it's not that bad to get out but I have done it a couple of times, the hardest part is getting the speedometer cable back in the cluster, very little room but I figured it out. Once I tightened that one screw thats been rattling and driving me nuts for years is now gone, nice and quite now. There could be a couple of more screws in the center of the dash bolted to the bar with the same issue as on my driver side. The center of the dash is pretty much hidden with the air vents A/C contols and radio so I couldn't see behind there and I've never had to take any of that out. So good luck and check it out, hopefully you will find something like I did.
  7. Feb 2, 2009 at 2:53 PM
    kevind_
    96 Tacoma SR5
    alright thanks for the feedback guys, hopefully i get the chance to do it this weekend.
  8. Feb 2, 2009 at 3:13 PM
    Racinkid13
    Racinkid13 Problem Child
    Kent,WA
    SR5 TRD debadged and beaten
    many
    Mine rattled too....until i turned up the radio.
    Now, i worry when things stop rattling.
  9. Feb 21, 2009 at 7:41 AM
    stonecutter908
    stonecutter908 Member
    West Chester, PA
    95 Ext Cab v6
    I'm having this same rattle on my 95. Just started this morning, which happened to be very cold out at 6am here in PA. First hunch, was that is was the weather. But after the truck warmed up it didn't go away. .
    My rattle is on the far left of the instrument panel and I have another symptom tied to it ... the speedometer shakes like crazy while the rattle is going. All other dials are ok but the speedo vibrates between 5mph below and 5mph above my actual speed. When stopped on going slow ... nothing. When in 3rd through 5th gears and my speed is picking up, it gets worse.
    Any ideas?
  10. Oct 16, 2010 at 2:22 AM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    Im having the exact same issue with mine. Right above the center vents. It does go away though after a few minutes of driving.
    So none of this would be covered under a recall? How much would the dealer charge for the fixes called for in the TSB?
  11. Oct 16, 2010 at 6:37 AM
    Gieser
    Gieser Official Flatlander
    MB, Canada
    06 tundra yamaha edition
    scion Head Unit and magnaflow muffler...so far
    mines more in front of the passenger seat. so i just stuffed some paper in there and it kinda helped
