Dashboard Shift Indicator
Discussion in '1st Gen. Tacomas (1995-2004)' started by kendubya, Sep 9, 2010.
  1. Sep 9, 2010 at 7:04 PM
    kendubya
    kendubya [OP] Active Member
    Chicago
    2003 SR5 TRD
    billy 5100's, aal's, , leer shell, thule pro ladder rack, rubber antenna mod, silver stars, weathertech mats, ram mount custom droid x dash mount
    Anyone done/heard of a mod to add a dashboard gear indicator to an '03 taco automatic?
  2. Sep 9, 2010 at 7:06 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    If you have an automatic then for what purpose do you want one for as you really have no control over shifts? :confused:
  3. Sep 9, 2010 at 7:12 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Do you mean like an indicator as to what gear you're in?
  4. Sep 9, 2010 at 7:19 PM
    kendubya
    Chicago
    2003 SR5 TRD
    yeah, should have called it a "gear" indicator
  5. Sep 9, 2010 at 7:22 PM
    kendubya
    Chicago
    2003 SR5 TRD
    should have said "gear" indicator. What? Like you've never manually shifted an automatic tranny? ;)
  6. Sep 9, 2010 at 7:43 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    the gear indicator is on the shift nob plate thing there is no display in the dash
  7. Sep 9, 2010 at 8:56 PM
    kendubya
    Chicago
    2003 SR5 TRD
    Yes, but I want one on the dash, hence my original post.
  8. Sep 9, 2010 at 11:22 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Yeah but you wouldn't need a shift indicator for that. :p
    Now that you've clarified, you can get something like this:
    http://www.dakotadigital.com/index.cfm/page/ptype=product/product_id=64/prd64.htm
    Or if your capable of doing it you could easily make your own using proximity sensors or contact switches & some LEDs. Might be too much trouble than what it's worth though.
  9. Sep 10, 2010 at 8:45 AM
    kendubya
    Chicago
    2003 SR5 TRD
    exactly...thanks
