Dashboard tire warning light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JDD, Nov 27, 2021.
  1. Nov 28, 2021 at 6:33 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    This^^
    People who laugh and say "I'll just carry an air pressure gauge in the glovebox" are completely missing the point of the system
    By that logic, what's the point of the oil warning light? Just check the dipstick right?
    Tex-Tac, wi_taco and steelcity2 like this.
  2. Nov 28, 2021 at 12:09 PM
    tacoanddogs
    tacoanddogs Well-Known Member
    2013 Black Tacoma DCLB
    Anyone know how to reprogram the sensor for aftermarket tpms sensors? I just got new wheels, tpms sensor and tires and the reset button under the steering wheel isn't working. I've got to take the spare into a shop bc I received it with leaky valve and need to swap it out with the new one so maybe they can get the button to work?
  3. Nov 28, 2021 at 2:38 PM
    Waasheem
    Waasheem
    2007 xrunner
    This might help. Mine has a sensor on the spare, but the tire doesn’t hold air for more than a few hours. So my dash light stays lit, unless I crawl under, put some air in the spare, then it goes off for a few hours. Maybe if you separate the spare from the vehicle, it’ll go out, not sure about that.
  4. Nov 29, 2021 at 3:16 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I guess i'm old school and check the oil and tire pressure on a regular basis... been doing it for the last 50 years. It only takes a couple minutes and you don't have to rely on a light bulb to work.
  5. Nov 29, 2021 at 3:24 PM
    OffroadToy
    Or you can take the sensor out of the spare and put it in a pressurized container and throw it in the glove box...
    Tex-Tac and Taco 422 like this.
  6. Nov 29, 2021 at 3:33 PM
    CVYota
    CVYota Damaged goods
    Andy
    Crescenta Valley
    2011 DCLB V6 4WD
    The sensor keeps flashing on my 2011. I already disabled the system. The sensors are in my garage and the batteries died on one of them. It goes away after a bit.
    I removed them because of offroading. Rip off a valve stem a couple of times and you are done.
    For the street, I see the need.
  7. Nov 29, 2021 at 4:49 PM
    No Shoes Nation
    No Shoes Nation Well-Known Member
    2008 Taco SR5 Access Cab 4.0 4x4
    Hmm . . . none as yet, that's why i'm here . . .
    Ahh the old pope bomb. Put all 5 sensors in there and get back to using a gauge once a week
    Yes I know this defeats the object of the system but it’s much easier and less expensive
    Us old farts like old school methods
    OffroadToy likes this.
  8. Nov 29, 2021 at 7:19 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    So, how does the pencil gage help you at 70 mph when a tire picks up a nail????
    The TPMS was mandated in the FMVSS after the Ford/Bridgestone rollover mess that killed and injured many people.
    It is a safety system designed to WARN of a deflating tire. It is not designed to replace a pressure gage.
    A few extra seconds of warning at 70 mph can allow a driver to slow and exit to the shoulder before a bad situation develops.
    I am an old fart who regularly uses a pressure gage to maintain tire pressure. But I also keep the TPMS functional and IN THE TIRES.
    Tex-Tac, steelcity2 and b_r_o like this.
  9. Dec 1, 2021 at 9:14 AM
    No Shoes Nation
    I fully agree. I also like a lot of folk don’t want to spend the extra on new sensors. At some point I’m sure I will see the error of my ways just hope it’s before picking up a nail at 70.
  10. Dec 1, 2021 at 10:08 AM
    Knute
    In comparison, the extra expense of the TPMS sensor is really small when compared to a roll over or a sudden excursion through a ditch or losing control impacting another vehicle.
    Just spend the extra $30/tire when you buy new rubber. I mean a set of tires with mount/balance/disposal/tax will be over $1000, another $120 is small.
    Don't step over dollars to pick up pennies.
    eherlihy likes this.
