Dashcams?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 19glendale, Aug 7, 2017.
  1. Aug 7, 2017 at 5:52 PM
    19glendale
    19glendale [OP] Well-Known Member
    Northern Virginia
    2017 Tacoma TRD OR 4x4 DCLB Silver with Tech & JBL
    N-Fab 3-Step Bed Access steps Fold-a-Cover G4 Elite Smittybilt Beaver Step hitch step Husky WeatherBeater floor mats Hondo Garage Premium Radio Knobs Carista OBDB connection + app TW +5 hp
    Does anyone run their dashcam on the Gopro mount and if so, what's your setup?
    Thanks
  2. Aug 7, 2017 at 6:15 PM
    Qwack
    Qwack Well-Known Member
    Oahu
    2016 TRD Sport 4x4 2017 4Runner
    no.
    ideally toyota should have a cam built into the rear view mirror.
    the gopro mount doesn't have a power supply
  3. Aug 7, 2017 at 6:17 PM
    Bishop84
    Bishop84 Well-Known Member
    I had a camera mounted to the go-pro mount, it was too far away to operate and check. I have a hardmount that attaches to rearview mirror that I opted for instead.
  4. Aug 7, 2017 at 6:27 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    No.. I have a BlackVue DR650S 2CH dash cam and I just had to replace the windshield due to oncoming rock that did not miss the window... The BlackVue 650S has the front and rear camera and great quality video....
    I just went out to B.C. and back... it recorded everything....even the rock that killed the windshield....!!
    I got a new windshield WITHOUT that stupid mount.... (I did remove it from the old one...if anyone wants one..free)..!
    The Blackvue sticks to the window in the center of the window...(or anywhere YOU want it)... if I put it in the Go Pro mount, it would be so far off-center as to make the video very "off center"...!
    Kilokato, Dirty Harry and The hammer like this.
  5. Aug 8, 2017 at 8:39 AM
    boatguy
    boatguy Member
    2017 SR5 Access cab
    I mounted a Z-edge Plus. There is an earlier post with a photo of the aluminum block I machined and I had to epoxy the camera goose neck to the block. I think there are a lot of ways to pull it off depending on which dash cam you are looking at. I'm very happy with result.
  6. Aug 8, 2017 at 10:43 AM
    ICU1
    ICU1 Well-Known Member
    Gopro Five. No problems. I use usb port to keep unit charged. I use phone app to control unit
  7. Aug 8, 2017 at 10:47 AM
    gilcrestk
    gilcrestk Well-Known Member
    2016 Tacoma TRD O/R DCSB
    I have a gopro mounted to my gopro mount.
  8. Aug 8, 2017 at 1:06 PM
    Rownan
    Rownan Well-Known Member
    Tim
    Highland, MI
    '17 OR DCSB 6MT *Quicksand*
    yep, I have a z-edge Z3 mounted to mine. Works great. The Z3 is one of the few dashcams that use the screw mount attachment like a standard camera, so there are tons of adapters available for a gopro mount. The biggest pain I had when searching for a dashcam was how I was going to adapt it to the gopro base.
    Ran a micro-usb wiring kit under the headliner with an add-a-fuse.. Looks very clean. I forget it's there most of the time.
    McEZ likes this.
  9. Aug 8, 2017 at 1:27 PM
    DA3
    DA3 Well-Known Member
    USA
    Paypal me 60 bucks and I'll send you my garmin with GPS - in box dash cam.. google it. (USA only guys)
  10. Aug 8, 2017 at 1:36 PM
    over60
    Muskoka, Ontario
    What model would that be... not that I'm interested, as I have a cam already....but no-one can see what it is without that info..!
    Cheers.
  11. Aug 8, 2017 at 2:53 PM
    Slim_shadowz
    Slim_shadowz Well-Known Member
    17 Sport DCLB MGM 4x2
    Where did you tap the power wire into? Pics of your install please. I've been looking at the Z-edge as well and want to hardwire it in so I do not lose my 12v.
  12. Aug 9, 2017 at 3:28 AM
    DA3
    USA
    Garmin 20 - but it's gone already
  13. Aug 9, 2017 at 8:12 AM
    Rownan
    Tim
    Highland, MI
    Sure, I'll get some pics.
  14. Aug 9, 2017 at 9:38 AM
    bradshawnh
    bradshawnh ...to the rescue!
    Boston, MA
    2017 TRD OR DCSB 6MT, Tech, Inferno
    With a 3D printer or some spare GoPro mounts and creativity, anything is possible!
    I've used the GoPro mount for a radar detector (but that blocked the passenger side visor from going down all the way) and a dash cam in the past. I now have my dash cam stuck behind the mirror so I can't see it, and the GoPro mount unoccupied. Maybe I'll use it for a time lapse or something.
    Power comes from the overhead console, a short few inches away. Auto dimming mirror, switches, and the moonroof all have switched/constant power/illumination feeds.
  15. Aug 11, 2017 at 3:51 PM
    ThePines
    ThePines New Member
    Does your GoPro charge while recording and plugged into the USB? When recording my GoPro battery drains even when plugged into the USB. Not sure if it's a GoPro or Toyota issue.
  16. Aug 11, 2017 at 4:35 PM
    i8boots
    i8boots Well-Known Member
    UT - 801
    2017 MGM DC SB TRDOR JBL
    Hood/bed lights, pop-n-lock, RSI EvoA, fully custom fuse box, Husky mudflaps, white interior LEDs, Morimoto xB v2 Headlights, Bilstein 6112/5160, Sumo Springs, Meso puddle pods and overhead lights, anytime backup mod, light out in reverse mod, ac drain mod, Calirased CAT protectors, ARB Dual Air in bed.
  17. Aug 11, 2017 at 5:56 PM
    ICU1
    My GoPro will continue to charge when recording, but the charging process can be slow at times.
  18. Aug 13, 2017 at 9:36 AM
    ThePines
    ThePines New Member
    Thanks. Mine just drains while recording :(
