Dashlights stopped working after service.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by acugirl, Jul 12, 2024.
  1. Jul 13, 2024 at 11:26 AM
    acugirl
    acugirl [OP] Member
    2017 Tacoma TRD
    Thank you everyone! If you can think of anything else please let me know. I will let you know what happens!
  2. Jul 13, 2024 at 11:27 AM
    acugirl
    acugirl [OP] Member
    2017 Tacoma TRD
    Wish you were here!
  3. Jul 13, 2024 at 11:29 AM
    acugirl
    acugirl [OP] Member
    2017 Tacoma TRD
    It only goes as bright as the night time lighting, very dim. There is no day lighting at all on the dash.
  4. Jul 13, 2024 at 6:00 PM
    acugirl
    acugirl [OP] Member
    2017 Tacoma TRD
    THE MYSTERY DEEPENS....9 FUSES are not working under the hood. Haven't checked the the ones under the dash. I don't know what they are for, anyone? Or where to look them up?
    At the top, it is the 4 in the upper right hand corner, 3 10A fuses and 1 15A. Staying at the top the last 2 10A on the left hand side.
    Then at the bottom left, the bottom of the horizontal fuses, 3 10A.
    EFI NO.3
    INJ
    H-LP RH-HI
    H-LP LH-HI
    EFI NO,4
    A/C
    BKUP LP NO.2
    H-LP LH-LO
    H-LP RH-LO
    https://photos.app.goo.gl/2FzjH1ascxAWUeVr5
  5. Jul 13, 2024 at 6:46 PM
    caribe makaira
    Caribbean, Puerto Rico
    All those are after relays, meaning power doesn't go through them if circuit is not active and/or engine on.
  6. Jul 13, 2024 at 6:56 PM
    acugirl
    acugirl [OP] Member
    2017 Tacoma TRD
    They look just like fuses. Why are you saying they are relays? CAN i check them with the engine running?
  7. Jul 13, 2024 at 6:57 PM
    acugirl
    acugirl [OP] Member
    2017 Tacoma TRD
    Did you see the photo?
  8. Jul 13, 2024 at 7:02 PM
    acugirl
    acugirl [OP] Member
    2017 Tacoma TRD
    They are fuses, not relays.
  9. Jul 13, 2024 at 7:14 PM
    caribe makaira
    Read again, slowly.
  10. Jul 13, 2024 at 7:27 PM
    acugirl
    acugirl [OP] Member
    2017 Tacoma TRD
    So you are saying that after relays are fuses? How do you test them with the engine running?
  11. Jul 13, 2024 at 7:27 PM
    acugirl
    acugirl [OP] Member
    2017 Tacoma TRD
  12. Jul 13, 2024 at 7:33 PM
    caribe makaira
    EFI NO.3
    EFI NO,4
    INJ
    Engine on, no need to test for they provide juice to the engine circuit Electronic Fuel Injection system.
    A/C
    If the Air Conditioner works (engine ON) no need to test.
    BKUP LP NO.2
    Fuse to Towing Reverse, test at rear bumper towing connector, pin 7. (center one)
    H-LP RH-HI
    H-LP LH-HI
    H-LP LH-LO
    H-LP RH-LO
    These are the headlamp fuses Low and High, Driver's side & Passenger's side.
    Jaragon likes this.
  13. Jul 13, 2024 at 7:49 PM
    acugirl
    acugirl [OP] Member
    2017 Tacoma TRD
    Thanks so much!
