Taco Garage - Dashtop Multi-Mount (DMM) - Securely mount ANYTHING to your dash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FreshMexicanTaco, Jun 10, 2018.
  1. Oct 29, 2018 at 4:29 PM
    #501
    Landpirate
    Landpirate Strong like horse, smart like tractor
    North Texas
    2018 Tacoma BBP SR5 4x4 DCSB
    OME HD leafs, 5100s, CaliRaised skids, UpTop Overland Bravo, KB Voodoo rack, Overlander RTT/awning, DECKED
    That looks great.
  2. Oct 31, 2018 at 8:47 AM
    #502
    Jesse5730
    Jesse5730 Active Member
    Jesse
    Tucson, AZ
    2017 Tacoma TRD Pro Cement
    I didn’t need more than one mounting option so I opted for the single mount.
    I was surprised at how easy this was to install, 10 minutes. Everything fit extremely well. I was a bit skeptical about how much I would like it, worried it would stick up too far but even when it’s vertical it doesn’t sit any higher than the hood so I’m not loosing any view. I was also not sure about the prong type of mount but it’s easy to get used to and with some of the bumpy roads around me I’m just not convinced a magnetic mount would stay put. The mount has been rock solid and because it’s so adjustable my phone will still unlock using facial recognition while mounted so it’s really easy to access when driving....a bit to easy to access as I find myself using the phone more often than I should.
    Overall I’m extremely happy with this mod.16058295-903C-477F-AF59-48B0CB6A83FC.jpg 72D18E6D-6B0D-4851-A0C8-5C0745DD8513.jpg 82EC08DC-3A01-47D3-9B17-CE7C88BA8483.jpg 37E6A6BC-3C6B-4136-B630-0F3053AFBF76.jpg E325A1E8-00D0-4290-BF81-54B012D7C580.jpg 333D92CF-9683-4ECB-9D86-B08AD047E71F.jpg
  3. Oct 31, 2018 at 9:33 AM
    #503
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yeah. Access is a bit too easy. You will train yourself to ignore it. Considering the frustration free navi, well . . .
    For training, I had a BT headset in my m/c helmet for 12yrs now. The learning was quick and easy since all of the folks who called knew that a conversation while moving was very secondary. That translates well to an in-car phone mount.
  4. Oct 31, 2018 at 11:00 AM
    #504
    FreshMexicanTaco
    FreshMexicanTaco [OP] The Taco Garage
    AJ
    San Diego
    2019 spiced up Taco with guac, no onions.
    Dashtop Multi-Mount!, Pro grille, snug top, Kings BFGs, Front and rear view camera anytime, CMC, prinsu and more to come!
    I agree that internally wired would be much better looking but I don't want to alienate non-electrical savvy taco owners, but then I though if you're brave enough to install the DMM then you should be OK with some simple wiring, so internal it is, at least for now...
    I am going to make it so that it bolts into one of the DMM holes and uses one of the other holes to run the wires, I'm trying to keep it as small as possible but most of the USB ports I have found are larger than what I would like
    Toynado and Landpirate[QUOTED] like this.
  5. Oct 31, 2018 at 11:42 AM
    #505
    dynamicweight
    dynamicweight Well-Known Member
    Is there any word how long the sale is going to last? I am pretty close to pulling the trigger, I can't stand that my current set up keeps falling off my dash in off roading situations, but I am also kind of bummed I can't find a ram ball mount with wireless charging for the day-to-day situations. Have people had any luck passing USB-C cords through the DMM holes?
  6. Oct 31, 2018 at 9:28 PM
    #506
    FreshMexicanTaco
    AJ
    San Diego
    The DMM is now $50 permanently. I was able to cut down on some costs as I increased production. I’m passing some of the savings to you guys.
    The holes on the DMM are not large enough to push a connector through. The wire would go through just fine bust not the connector.
    I’m working on getting some kind of USB port add-on to power devices.
    There’s also a few options out there for wireless chargers that will work with the ball mounts. Have you seen those?
    Steelhead Taco likes this.
  7. Oct 31, 2018 at 9:33 PM
    #507
    FreshMexicanTaco
    AJ
    San Diego
  8. Nov 1, 2018 at 10:58 AM
    #508
    dynamicweight
    yeah, the one I have has a ball like that but I didn't think it looked like the right size. Maybe I'll try it.
    Will your USB solution be backwards compatible do you think? As in I could buy now and buy the USB later?
  9. Nov 1, 2018 at 12:46 PM
    #509
    FreshMexicanTaco
    AJ
    San Diego
    Yes the USB power add on will be compatible with all DMMs sold up to date
  10. Nov 2, 2018 at 7:45 PM
    #510
    Steelhead Taco
    Steelhead Taco Oncorhynchus mykiss
    Fred
    2016 OR DC SB MT
    Been watching this thread and just ordered, my phone mount has dropped my phone for the last time!
    Great job OP! Can't wait to install and see what you come up with a power source.
    order WC-673, WC-674... forgot I needed 3 balls
    tonered likes this.
  11. Nov 4, 2018 at 2:26 PM
    #511
    FreshMexicanTaco
    AJ
    San Diego
    Thanks for your order! Look for that in you mailbox this week. Probably by Thursday.
  12. Nov 4, 2018 at 2:28 PM
    #512
    FreshMexicanTaco
    AJ
    San Diego
    Power source is in the works. I’m probably going to have the converter inside the dash with just a plug outside bolted to the DMM... not so easy to figure out though
  13. Nov 4, 2018 at 7:52 PM
    #513
    FreshMexicanTaco
    AJ
    San Diego
    POLL added. I appreciate your responses.​
  14. Nov 5, 2018 at 3:19 PM
    #514
    PB FAB
    PB FAB Well-Known Member
    2017 SR DCSB 4x4 v6
    Just ordered the DMM with two mounts. Can’t wait to test it out in Death Valley in a few weeks!
    Does anyone know is there is a mount that will fix a SiriusXM onyx mount? It has a really small ball.
  15. Nov 5, 2018 at 6:51 PM
    #515
    FreshMexicanTaco
    AJ
    San Diego
    I will get that out tomorrow!
    I’m looking into the onyx mount...
  16. Nov 5, 2018 at 9:28 PM
    #516
    FreshMexicanTaco
    AJ
    San Diego
    Actually... I think yours already shipped. I assumed you ordered when you posted the message but you ordered before that so yeah I’m sure it shipped already. You should see it by Thursday... ish
  17. Nov 6, 2018 at 9:43 AM
    #517
    dynamicweight
    My phone and GoPro both use USB-C now. I'm kind of curious how you're planning on adding the power cord though because both cords still use the regular full-size USB on the "getting power" end. Also, there are still idiots (I kid, I kid, mostly) buying iphones and their dumbass (haha still just kidding, not really) cords don't work with anything. So are you planning on having something other than full size female usb plug?
    C41n and doublethebass like this.
  18. Nov 6, 2018 at 9:47 AM
    #518
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That is kind of the crux of the poll added to the OP. USB-A is the full size that you are talking about. My phones with USB-C came with both USB-A to USB-C and USB-C to USB-C cords. That, IMHO, is the great thing about USB-C. The ends don't matter nor does orientation.
  19. Nov 6, 2018 at 12:54 PM
    #519
    FreshMexicanTaco
    AJ
    San Diego
    The easiest way to go is usb A which I might do no matter what. USB c is tougher because there’s less parts and they’re more expensive. I want this to be as clean of a salute on as the DMM...
    In either case it will be a female power-only plug in what I hope is a slim enclosure bolted to the dmm
  20. Nov 9, 2018 at 3:07 AM
    #520
    minium
    minium Well-Known Member
    2017 Inferno Tacoma TRD Off Road
    Not sure why the hate on iPhone devices, but none the less.... from a consumer standpoint USB-C should be preferred. There are USB-C to Lightning cables available, and new IOS devices are moving to USB-C as well.
    JKDer, Mtn Mike and doublethebass like this.
