Dave's Inferno
Discussion in '2nd Gen. Builds (2005-2015)' started by Dave41079, May 7, 2016.
  1. Feb 16, 2018 at 4:57 AM
    #621
    ScenicCityOverland
    ScenicCityOverland Well-Known Member
    Alex
    2015 Inferno Orange Tacoma TRD Pro
    Damn good looking truck man! Loving your old CBI rack too! :bananadance:
  2. Feb 16, 2018 at 2:32 PM
    #622
    Zacowacko
    Zacowacko Well-Known Member
    Zack
    SW, OK
    2013 DCSB TE 4x4 6spd
    TRD Pro Susp., Icon AAL, Bags w/cradles, US OR Bumper w/Smitty, 2Lo Mod
    Hey @Dave41079 . Any idea what your front setup weighs? I have 120lbs of US Offroad bumper and winch. Just bought the Pro Setup and wondering if i will need spacer or not. Thinkin i will AAL out back for extra 1.5". I dont have any weight in the back, but do have bags to handle when i tow my tractor. Thanks
    Dave41079[OP] likes this.
  3. Feb 16, 2018 at 4:21 PM
    #623
    Dave41079
    Dave41079 [OP] Words go here.
    Dave...
    Nashville, TN
    The shittiest of boxes
    Things, stuff, and whatnot.
    Just a guess, but I'd say around 150lbs max. I can remove/install it by myself, so it isn't super heavy.
  4. Feb 16, 2018 at 5:57 PM
    #624
    Zacowacko
    Zack
    SW, OK
    So did you add the 1"spacer that goes to bottom of spring? How's that pro setup run with that weight? I'm thinking about not using the spacer.
  5. Feb 16, 2018 at 8:23 PM
    #625
    Dave41079
    Dave...
    Nashville, TN
    I did the half inch top plate spacer. I did a 10,000 mile road trip over this past summer and it was a very comfortable ride. It also rides very well off-road, especially with the tires aired down.
  6. Feb 17, 2018 at 9:22 AM
    #626
    Zacowacko
    Zack
    SW, OK
    Was it the 1\2" spacer that gives you an inch or 1\4" spacer that gives you 1\2"? What was the reason for new uca? Couldn't hit #'s you want on alignment?
  7. Feb 17, 2018 at 12:38 PM
    #627
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Both. General rule of thumb, compress the coil half the length of how much lift you want.
  8. Feb 17, 2018 at 2:47 PM
    #628
    Dave41079
    Dave...
    Nashville, TN
    1/2" spacer so I got an inch...ish. UCAs were for ease of getting numbers I wanted.
    beertimecontinuum likes this.
  9. Feb 17, 2018 at 7:21 PM
    #629
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    Samesies, cept my spacer is DYF
    Dave41079[QUOTED][OP] likes this.
  10. Feb 17, 2018 at 9:01 PM
    #630
    Dave41079
    Dave...
    Nashville, TN
    I believe you mean "DYF AF."
  11. Feb 18, 2018 at 2:00 PM
    #631
    Zacowacko
    Zack
    SW, OK
    Thinking even if i go without the spacer, i may get some UCA's. Don't like the lean out i have now at 1.75"
    ChadsPride likes this.
  12. Feb 20, 2018 at 1:37 PM
    #632
    Zacowacko
    Zack
    SW, OK
    You remember what your #'s were before the spacer? Still on the fence on whether or not to do UCA's. :annoyed:
  13. Feb 20, 2018 at 1:50 PM
    #633
    Dave41079
    Dave...
    Nashville, TN
    I don't, it's been too long ago. I say do it without the UCAs and see what the alignment looks like. You can always put them on later.
  14. Feb 20, 2018 at 1:59 PM
    #634
    Zacowacko
    Zack
    SW, OK
    Thats probably what i will end up doing. I should be a little lower in front with my weight anyway.
    I got to fix the damn cam tabs a shop snapped off. Also have to build up my rear bracket for my bags to accommodate the AAL. Daystar cradles. What am i forgetting, lol. May just go ahead and do tie rods and ball joints while i am in there, lol... May be gettin close to time for those with 85k huh?
    Not having to do UCA too will save me some time.
  15. Feb 21, 2018 at 12:44 AM
    #635
    Dave41079
    Dave...
    Nashville, TN
    I did my UCAs in about an hour by myself. It isn't that bad...mostly.
  16. Feb 21, 2018 at 8:09 AM
    #636
    Zacowacko
    Zack
    SW, OK
    Ya, just bad for my wallet :spending:
    Is there such a thing as not having enough lift and installing UCA, that would then prevent you from hitting your alignment #'s? I only ask, cause not sure where i will end up with the TRD Pro setup and my extra 120lbs. Not sure what i will lose of that 2". I'd like to be able to hit 0 on my camber. I've got a slight hint of negative camber now and dont like how it looks. 1.75 on the billy's, but really think i may have ended up with more than that.
  17. Feb 21, 2018 at 10:33 AM
    #637
    Dave41079
    Dave...
    Nashville, TN
    It's really hard to say without just trying it and finding out. I was more concerned with my caster numbers, and getting the tire forward out of the firewall.
  18. Feb 21, 2018 at 11:46 AM
    #638
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Dave's answer is right but simply answering it with a "yes" is more right. :p
    Most aftermarket ucas have 3 degrees of caster built in so with no lift, your wheel would be 3 degrees worth of distance pushed forward (I'm not sure how far that is). Most ucas are non adjustable and since they only have added caster (not added -/+ camber) they are going to throw all 3 alignment points out of spec. Remember if you change 1 point, you change them all. And just like how adding ucas when lifted could get your specs back to factory, adding ucas when not lifted could never get your specs back to factory
    Dave41079[OP] and ChadsPride like this.
  19. Feb 22, 2018 at 3:11 PM
    #639
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Is this Brent's build thread?
    rngr, BYJOSHCOOK, Breezy and 3 others like this.
  20. Feb 22, 2018 at 4:24 PM
    #640
    Dave41079
    Dave...
    Nashville, TN
    Yes! You can end your quest.
    rngr, BYJOSHCOOK, 11TRDTX and 3 others like this.
