day 5 driving 2023 Tacoma...Key fob, tailgate questions...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BraveRifles3, Feb 21, 2025.
  1. Feb 21, 2025 at 5:54 AM
    BraveRifles3
    BraveRifles3 [OP] Active Member
    Hello All!
    I am driving a 2023 push-button-start Tacoma. I have a press button key fob that houses a stick key and on the same keyring I have a totally separate stick key. I assume one of the stick keys should lock the tailgate, but so far, neither key fit into the tailgate lock (tailgate lock may need oil?). Is the key that is housed in the fob a back-up door key and the solo stick-key dedicated to the tailgate? Or?
    As always, Thank You in advance!
  2. Feb 21, 2025 at 6:07 AM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    Does it have a pop n lock? Do you have a bed cover or can you reach in and open the tailgate? Is the truck new or was it purchased from someone?
  3. Feb 21, 2025 at 6:22 AM
    BraveRifles3
    Hello Greg-tacoma!
    I doubt Pop n lock is installed. If it is, it is not working; I can check that tonight. Tailgate opens and closes as expected. I have access to both sides of the tailgate. Truck is used but still under warranty.
    Best!
    .oto
  4. Feb 21, 2025 at 6:44 AM
    lastcall190
    lastcall190 Well-Known Member
    NJ
    2023 Silver DCSB TRDOR
    Both keys should fit the tailgate and vice versa (the fob-key might switch orientation versus using in the door itself, anyone correct me if I'm wrong).
  5. Feb 21, 2025 at 6:58 AM
    23MGM
    23MGM Well-Known Member
    2023 TRD Off Road
    I believe you're correct. My stick key fits the door and tailgate. It isn't as smooth as a traditional key, but it works. It only goes in one direction, at least for the door.
  6. Feb 21, 2025 at 7:06 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    @lastcall190 you are correct.
    The backup key within the key fob can be used to unlock both the doors and the tailgate, as there is no separate key for the tailgate. The stand alone works the same as well.
  7. Feb 21, 2025 at 7:10 AM
    lastcall190
    NJ
    OP to answer your other question, if the truck is used but still under warranty, might not hurt to just go to the dealer and ask what gives if you have one you trust.
    Oh, did you try either key in the front door as well?
    BraveRifles3[OP] and Chew like this.
  8. Feb 21, 2025 at 9:30 AM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    The keys only fit in the tailgate when correctly positioned. If it doesn't work try flipping the key the other way or 180 degrees. If you look at the key it is not identical on both sides.
  9. Feb 21, 2025 at 9:33 AM
    jdjones
    jdjones Well-Known Member
    2022 TRD Off-Road DCSB
    My 2022 OR came with a tailgate only key. I keep it in the center console.
    BraveRifles3[OP] likes this.
  10. Feb 21, 2025 at 9:42 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    If the key doesn't fit in the tailgate lock, I would research as to why? Was the tailgate repaired (accident?) or stolen? Who knows, it might not be a deal breaker, but if they jive together, I would want to know why.
    BraveRifles3[OP] and t0p_d0g like this.
  11. Feb 21, 2025 at 9:52 AM
    Greg-tacoma
    Greg
    2016 Black 4cyl 4wd
    As stated above the key should work, I’d take it back to the dealer and make it their problem. My key works door and tailgate. You can purchase a pop n lock, the one I purchased didn’t require any wire cutting or splicing.
  12. Feb 21, 2025 at 10:28 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    For curiosity I just went out and checked the fob key and the stand alone key and they both work door and tailgate on my 2023.
  13. Feb 22, 2025 at 7:13 AM
    BraveRifles3
    BIG Thank You, All! Much appreciated!!
    UPDATE: It took a while but after light manipulation and a few micro coats of olive oil on key shaft, I was able to fully insert each key in tailgate lock and verify each work to lock and unlock the tailgate. It's almost like the lock had never been used.
    It was after work and late. I'll go back later to verify key to cab lock function.
    ... with this newfound knowledge, I parked the full sized stick key, ...now, one less key to carry around all the time!
    Chew and shark56 like this.
  14. Feb 22, 2025 at 7:22 AM
    Inyo_man
    Inyo_man Don't piss down my back and tell me it's raining.
    U.S.A.
    2023 Tacoma TRD, off-road, access cab
    ...glad you got that figured out.
    For what it's worth, I would recommend using graphite lube on locks/keys for smooth operation, instead of olive oil.
    Cheers
    TheWildMan and BraveRifles3[OP] like this.
  15. Feb 22, 2025 at 7:22 AM
    Greg-tacoma
    Greg
    2016 Black 4cyl 4wd
    Great news, I would use graphite, oil will collect stuff and ail over time. Look into a pop n loc. it is really great once you have a cover
    Chew and BraveRifles3[OP] like this.
  16. Feb 22, 2025 at 7:37 AM
    TAZMINATOR
    TAZMINATOR Well-Known Member
    2017 Tacoma
    Pop n lock is an add-on. That means you can install it in the tailgate by yourself. That way, you can un/lock the tailgate with your FOB instead of the tailgate key.
  17. Feb 22, 2025 at 8:41 AM
    BraveRifles3
    Thanks again All!
    RE: Pop n Lock. I was disappointed that a Pop n Lock type system was not included on this Tacoma especially since the truck is "option heavy" :(. . ...I was expecting front parking sensor, too, but, oh well...
    ...Folks on this forum mentioned a Toyota coupon (THANKS!) I was able to order the Toyota version of Pop n Lock right before the coupon expired. ... Price was close to same after discount. Not installed yet. Maybe when weather and temperatures improve.
    I appreciate you folks!!!
    Best!
    .oto
    lastcall190 and Chew like this.
  18. Feb 22, 2025 at 8:59 AM
    Azrael's Gaze
    Azrael's Gaze Well-Known Member
    Steve-O
    Springfield, Oregon
    2022 Black Tacoma TRD Offroad
    For my 22 OR the seperate key and the one in the fob both work for the tailgate
  19. Feb 22, 2025 at 9:01 AM
    canuck guy
    Alberta
    23TRDOR
    I prefer to use the full size key. The one in the fob seems fragile in my large paws and I don't like having to fish it out of the fob to use.
  20. Feb 22, 2025 at 8:24 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    why olive oil? are you a chef?
    t0p_d0g likes this.
