Day Time Running Lights 2011 Tacoma
Discussion in 'Hawaii' started by kh7nm, Nov 30, 2012.
  1. Nov 30, 2012 at 7:03 PM
    kh7nm
    kh7nm [OP] Stay Boosted
    Miles
    Ewa Beach, Hawaii
    2011 MGM DC 4x4 TX PRO Off Road
    What have you done to your truck lately
    Just wondering if anybody having problems with there day time running lights. Went the Dealership for my last free oil change and the guy said your day time running light lens is starting to melt and it needs to be replaced. $1,000 to replace both but since it is under warranty it's free. Truck is only 1 years old and all stock lighting in the head lamp. Also the Service guy said it will not pass safety check so gotta change.
  2. Nov 30, 2012 at 7:19 PM
    TacoHI11
    TacoHI11 Member
    Oahu
    11 double cab sport
    Had the same thing on my 2011. Dealer replaced lights last week. Free! Can not complain took two hours.
  3. Nov 30, 2012 at 7:20 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    its a common problem with these trucks...some done experience it and some do
    good thing youre still under warranty
  4. Dec 1, 2012 at 3:17 AM
    Kala
    Kala Well-Known Member
    BigIsland
    05 PreRunner SR5
    How does it take 2 hours changing head lights? Are they pulling it apart and changing lenses inside the housing or replacing the whole headlight? It should take you 20-30 minutes....geeez.
  5. Dec 1, 2012 at 8:21 AM
    kh7nm
    Miles
    Ewa Beach, Hawaii
    It took 2 1/2 just to have Servco change oil and rotate tires. But it was free.
  6. Dec 2, 2012 at 9:46 AM
    tx novice
    tx novice Foward momentum
    Ron
    OAHU
    11 DC 4X4 TX PRO silver
    Trd, Cal Tech, Weather tech, Viper, Al's tinting . L.E.D's , Hide a Hitch or Chrome Stinger , Walker Evans Resi's w/AllPro 3" lift ,FLM, ProComp Xtreme MT2 , Diff Breather Mod, 4x4 Switch Light mod, Plastic Derped. Trailer Socket Relocate mod via Miles , 4:56 G2 gears. Blue Intake Spacer, S.S. Brake Lines F&R, Sway Bar Deleted, Roll-X, Pop-N-Lock Electric. Red metal TRD badges. Paid Off Mod- Chee Hu, Superbumbs(f),Timbrens(r).Pelfrey Bilt, Bamf, Urd. Cobra Heat Shield.CMC .Mishimoto (custom bracket by Nate), Powerstop, Rampage 50".Depo Taillights,SPPC Black Headlights, Rigid Industries. Factor 55.American AirFlow.
    Yes. It's a known problem at Toyota. Change them for free then put l.e.d's in. They won't melt anymore. I got mine from superbriteleds.com :D
  7. Dec 2, 2012 at 11:37 AM
    tx novice
    Ron
    OAHU
    Here's the LED running light. Not as bright but no more melting. also, I put LED fogs.
  8. Dec 2, 2012 at 7:05 PM
    kh7nm
    Miles
    Ewa Beach, Hawaii
    Do you have part numbers for the fog looked on the web site and no cross match number for the fog lights. Thanks for the info.
  9. Dec 2, 2012 at 8:36 PM
    tx novice
    Ron
    OAHU
    HB3-WHP28-DRL..cool white 6k
  10. Dec 3, 2012 at 11:24 AM
    .666 Member
    Oahu
    .IconCamburgTotalchaosDakarMethodDuratrac.
    Replacing LED bulbs for DTRL plug and play?
  11. Dec 3, 2012 at 3:15 PM
    lemon177
    lemon177 Well-Known Member
    Matthew
    Oahu
    09 tacoma 4x4 sport pyrite mica
    TRD supercharger, URD 2.85" stealth pulley, TRD exhaust, TRD intake, DTLT headers, URD y-pipe, TRD boost gauge, PLX DM100 touch with OBDII and SM-AFR modules, 885 OME 3", Icon UCAs, Satoshi grill, Solid rear window, SCS stealth 6, 285/75/17 toyo AT2.
    Not sure, I heard things about blowing fuses and needing resistors, depending on the LED. I got a pair fir my dtrl that im still to scared to install.
  12. Dec 3, 2012 at 3:19 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    fuses blowing?? never heard that...99% of the people i know that has them have had them for over a year no problems
    you add the resistor for the hyperflash not to occur
  13. Dec 3, 2012 at 3:35 PM
    lemon177
    Matthew
    Oahu
  14. Dec 3, 2012 at 3:40 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    That addresses the hyperflash, there is not a problem with blowing fuses when switching to LED that I'm aware of. LED's have a significantly lower draw than the bulbs they replace. The lower draw is what causes the hyperflash (since the blinkers work off resistance). The same reason is why you won't blow fuses when switching to LED's, they have very low draw so when being used as a direct replacement for an incadescent or halogen, they should never overload the circuit.
  15. Dec 3, 2012 at 3:57 PM
    lemon177
    Matthew
    Oahu
    2. You need to use SRCK wired 3157 LED bulbs as sold by autolumination, due to the way the bulb socket is wired. The normal ones will be shorted when plugged in and will blow a fuse.
    Sorry for my lack of knowledge, but it says word for word. I know its a minor thing to blow a fuse, but the whole ordeal seems like more of a headache than its worth.
    I ended up replacing my headlights through toyota and they told me these new headlights shouldn't have the melting problem.
  16. Dec 3, 2012 at 4:06 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    never heard of that place...well the leds that csjumper2003 sells are direct plug and play with the 2nd gen tacomas...
  17. Dec 3, 2012 at 4:11 PM
    lemon177
    Matthew
    Oahu
    Im assuming his LEDs have a resistor in them. Im not sure if mines do too, I bought them from a random race shop. The guy even told me they might blow a fuse on the first test, bit if they don't then they'll be fine. Sounded sketchy to me but I bought them thinking it'll stop my headlights from melting further. Since I replaced the burned ones with the new ones, I haven't worried since and now im stuck with these $60 3127 bulbs.
  18. Dec 3, 2012 at 4:16 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    his you add an external resistor with a t tap right behind the bulb itself (wiring by the plug)
  19. Dec 3, 2012 at 11:09 PM
    kh7nm
    Miles
    Ewa Beach, Hawaii
    Your day time running lights did you get the 18 SMD or the 45 SMD? IS the brightness the same as stock?
  20. Dec 5, 2012 at 11:23 AM
    tx novice
    Ron
    OAHU
    Not sure which SMD it is but, I entered my year, make and model , which light I wanted to replace and that was one of the choices. The LED is WAAAAAY brighter than stock. It's a perfect marker light but sucks as a projector.
