Day Time Running Lights On with Headlights?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ZannarTacoma, Mar 6, 2014.
  1. Mar 6, 2014 at 3:32 PM
    ZannarTacoma
    ZannarTacoma [OP] Member
    Zack
    Colfax, CA
    07' PreRunner TRD Off-Road
    Raptor style grill lights Day time running lights
    So normally when you turn on the headlights the DRL's turn off. Is there a way to have both on??
  2. Mar 6, 2014 at 4:05 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    This method depends on the type of DRL you have. There should be 2 different filaments in the bulb. One for turn signal and one for the DRL. Same with the bulb plug. Seperate wires for DRL and turn signal. As long as the turn signal doesn't use the DRL filament, (turn signal uses seperate filament than the DRL) this method will work.
    Remove the wire in the plug to the bulb that is for DRL. Splice a wire from the parking lamps and put it in where the DRL wire was in the plug. Now they will turn on with your parking lights and headlights.
