Day Time Running lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by randy2000, Dec 15, 2010.
  1. Dec 15, 2010 at 4:29 PM
    randy2000
    randy2000 [OP] New Member
    Randy
    Honolulu
    2011 Prerunner
    None
    I purchased a 2011 Prerunner. It came with Day time Running Lights. I do not want these lights to be on while the engine is running and the head lights are off! I believe a relay switch for the turn signals/hazard lights controls the Running lights. Question: What is the part number that will disconnect the Day Running Lights?
  2. Dec 15, 2010 at 5:01 PM
    paidfor
    paidfor Well-Known Member
    Austin, TX
    2013 TRD OR 4x4
    Hidden GPS tracking system. Backflip cover, weather techs, bed mat, tailgate lock, OME 885 springs, blistein shocks, 2.5 in AAL/
    so you do not want people to see you during the day when you are riding around? That drives me nuts when I go to work in the early morning and I see people driving around with NO lights on at all. Makes me think they were told using your lights burns more gas.
  3. Dec 15, 2010 at 5:04 PM
    paidfor
    Austin, TX
    2013 TRD OR 4x4
    BTW....welcome to Tacoma World.
  4. Dec 15, 2010 at 5:06 PM
    AriZonaD54
    AriZonaD54 BANNED in 49 states...
    Andrew
    Valley of the Sun
    Umm... I just asked the dealership to hook it up to their computer and turn it off. They did. It's now off. Problem solved.
  5. Dec 15, 2010 at 8:41 PM
    three west
    three west Well-Known Member
    JD
    UP MI
    09 DC SB TRD Sport
  6. Dec 15, 2010 at 9:01 PM
    ouyin2000
    ouyin2000 Well-Known Member
    Nova Scotia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    You mean it doesn't? :confused:
  7. Dec 17, 2010 at 5:30 PM
    randy2000
    Randy
    Honolulu
    2011 Prerunner
    None
    Thanks to CROM dated 04-05-2010 I found the wire to cut so that I can either park with the engine running or drive w/o the headlights on and not have the DTRL glaring out. To "paidfor", I'm a safe driver.
    Having said this, I'm having trouble locating CROM's instructions. I'm new to TW and navigating this site. I'm sure I'll find it. Thanks for all the comments and help and what a great web site, and I do love my truck! :)
  8. Dec 17, 2010 at 8:59 PM
    Gregman
    Gregman Well-Known Member
    Freddy Beach, NB
    05 DC LB 4x4 SR5
    Maybe dude just wants some privacy when he's parking with his girlfriend in the evening, you know, heater running but lights out. ;)
  9. Dec 17, 2010 at 10:53 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Step on the parking brake ;)
  10. Dec 17, 2010 at 11:27 PM
    warpwr
    warpwr Junior Senior Member
    Vaughn
    S.F. Bay Area
    09 Sport Access Cab
    DRL mod with switch, rear spring TSB, trans TSB, tailgate mod, snug-top shell.
    you can put a switch in the circuit too.
    This thread is located at:
    http://www.tacomaworld.com/forum/te...time-running-lights-install-oem-new-post.html
  11. Dec 18, 2010 at 5:41 AM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    The way the daytime running lights is implemented by the Toyota distributors creates a big problem. They use the turn signals as the DTRL at full brightness. Unfortunately the headlight housing is not built for the heat level that builds up from the turn signals being always on and my enclosure is melting from the inside.
    Has anyone else experienced this?
  12. Dec 18, 2010 at 6:18 AM
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    Sure it's just not that heat in south Florida causing it. I would think if this happens it would be covered under warranty.
  13. Dec 18, 2010 at 9:17 AM
    warpwr
    Vaughn
    S.F. Bay Area
    09 Sport Access Cab
    http://www.tacomaworld.com/forum/2n...ve-they-damaged-your-headlights-new-post.html
  14. Dec 18, 2010 at 9:24 AM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    You guys might want to look for LED bulbs for your blinkers.;)
  15. Dec 18, 2010 at 10:34 AM
    OZ-T
    Peter North
    British Columbia
    All of the Canadian trucks have to have the DTRL as standard . I have been following this issue and the odd thing is that of all of the people posting about melting lenses , I can't remember a single one of them being from Canada . :confused:
  16. Dec 18, 2010 at 10:47 AM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    I look at it the other way. DTRL's, especially with the case of cars that use the headlights at a lower power, make people stupid. The cases I see of people running NO lights at all when they should is way lower than the amount of cars I see driving in the pitch dark with no lights on cause they don't realize that their DTRL's aren't their normal lights so they have no other lights on other than half powered headlights, and no rear lights on. Granted, this could be fixed by ALSO having lights that automatically come on when it's dark, but there are a lot of cars with DTRL's but no auto headlights. Saying every car should have DTRL so your car can always be seen when the driver is too dumb to know when to turn lights on is like saying you should just limit every car to 65mph so no one speeds.
    All the added car features in the world can't completely fix the fact that some people just shouldn't be on the road.
  17. Dec 19, 2010 at 8:43 AM
    coffeesnob
    VA
    Has anyone else had an issue with the dtrl's melting the headlight enclosure?
  18. Dec 19, 2010 at 8:56 AM
    jandrews
    '09 FourDubDee TRD OR
    No, but I removed the stupid yellow and orange lenses when I did the BHLM. Headlights look like hell when not clearcornered.
  19. Dec 19, 2010 at 9:06 AM
    Kahunadave
    Kahunadave Well-Known Member
    Dave
    Orlando, FL
    05 DC PrernrTRD Sport
    K&N CAI-series 63, custom Billet Grille, Magnaflow exhaust, AR Tactic 17x8, Toyo A/T opencountry 265/70/17, Iridium plugs.
    a few threads on here re. DTRLs melting. Just do a search for DTRL.
  20. Dec 19, 2010 at 12:19 PM
    toyoda
    toyoda Active Member
    2010 SR5
    The link to the Stealth Mode thing is what you want. You don't need to put a switch or anything if you don't want, just snip the wire in half. To be honest you don't even need to wrap the ends with electrical tape, they won't touch anything. It works like a charm.
