day1player’s cement build
Discussion in '3rd Gen. Builds (2016-2023)' started by day1player, Dec 12, 2019.
  1. Jul 7, 2020 at 1:54 PM
    SnuggleTruck
    SnuggleTruck Well-Known Member
    Alex
    Fort Myers
    2020 DCLB TRD OR
    TRD 2" lift shocks Icon AAL (gave me 1" lift with OL leaf out) 17x8.5" -12mm Trail Edition OEM replica wheels by FSW BF Goodrich KO2s (285 70 17) ECGS bushing OME carrier bearing drop kit TRD Pro skid plate Truxedo roll up Tonneau cover MESO - led interior light kit, blackout kit and gashole Toyota door sill protectors and bed mat
    I’m planning to do these exact wheels and tires when my stock tires are in need of replacement. Following your build and will look for when/if you solve the rubbing as I don’t want to have to deal with any rub at all. Looks good! DCLB OR in Cement 4L!
    day1player[OP] likes this.
  2. Jul 8, 2020 at 7:39 AM
    day1player
    day1player [OP] Well-Known Member
    Denver, CO
    2020 Tacoma TRD Off Road DCLB
    @SnuggleTruck Thank you! As far as the rub goes it is about 99% gone now. I only rarely ever hear it. That final adjustment I made to 15mm and 13mm actually worked pretty well, what I needed was an alignment. After I got an alignment, almost 0 rubbing.
  3. Jul 8, 2020 at 2:49 PM
    SnuggleTruck
    Alex
    Fort Myers
    2020 DCLB TRD OR
    Good to hear. Is the rub on the cab mount or just the wheel well plastics? I’m fine with heating and cutting some plastic on my truck but I’m not planning to do a CMC. Thanks!
  4. Jul 8, 2020 at 2:59 PM
    day1player
    Denver, CO
    Only rubs on the plastic. Only has ever rubbed on the plastic. And in this case, I have the factory mud guards which make it more likely to rub. And again, with the alignment, barely ever rubs
  5. Jul 8, 2020 at 3:16 PM
    SnuggleTruck
    Alex
    Fort Myers
    2020 DCLB TRD OR
    Awesome!! Thanks! At the 15 and 13mm adjustments what does that put the lift to in the front from stock height? From what I know the max height adjustment with the BP51 is 2”. Really looking forward to this lift, tire, wheel combo in my future!
  6. Dec 7, 2020 at 11:16 AM
    Drumminguy81
    Drumminguy81 Active Member
    If you ever take your camper shell off snap a couple pictures. I'm looking at getting the uptop alpha, my truck looks pretty similar minus the shell.. I really like the paint match.. how is the wind noise? Sunroof works fine still?
  7. Dec 7, 2020 at 11:38 AM
    day1player
    Denver, CO
    @Drumminguy81 I will take some photos for sure, but it's not likely to happen since I sleep in the back for trips and its mounted with a water resistant gasket.
    I love the rack, it looks so great especially with the paint match. The wind noise is basically non-existent compared to the Front Runner I had on my previous truck. They have a few options for the front wind plate, some of them have cutouts for light bars. Since I was not planning on a lightbar on the roof, and wind noise was a concern for me, I got this solid one with no cutouts. Thats probably something to keep in mind. On the bright side if I decide later to get a light bar up there, I can just reach out to the UpTop guys and purchase a new wind plate. They bolt in so they are replaceable.
    As far as the sunroof, it works perfectly. You will want to make sure you select their "Fresh Air" kit when you order your rack because that one comes with some adaptions to ensure the sunroof opens all the way.
  8. Dec 7, 2020 at 2:07 PM
    Drumminguy81
    How is the paint match? Is the color right? Paint holding up well?
  9. Dec 8, 2020 at 12:46 PM
    day1player
    Denver, CO
    The paint match is great. It looks like a perfect match.. My rack is coming up on 10 months old now, about 10k miles on the truck and there are no signs of wear, no chips or flaking paint. Its good quality
  10. Dec 27, 2020 at 8:42 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Great build Bro. Great looking truck
