Daylight running lights not working sometimes
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DCJeeper, Mar 22, 2019.
  1. Mar 22, 2019 at 9:36 AM
    DCJeeper
    DCJeeper [OP] Well-Known Member
    My 17 TRD OR has the L shaped LED daylight running lights. It's on if I turn the switch to DRL and is off when headlights are on. This week the DRL didn't turn on in the morning when I started the engine and turn the switch to DRL. I has to switch to parking light then both DRL and parking lights were on. It seems even I switched to headlight the DRL was still on. However, after I drove it back home in the afternoon the DRL worked as usually. I've noticed it for a few days and not sure if there's a setting that I accidentally changed on my smart key or if it's the cold temperature affected a sensor somewhere. Anyone has seen similar problems?
  2. Mar 22, 2019 at 9:39 AM
    Jaque8
    Jaque8 Well-Known Member
    2017 Inferno TRD OR
    They don't turn on until you put it into drive or reverse.
    If you just turned on your truck and had it in park the DRLs won't be on
    Hank Heel and Midknight like this.
  3. Mar 22, 2019 at 9:48 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Won't work w ebrake up.
    Garyji likes this.
  4. Mar 22, 2019 at 9:48 AM
    INFERNOtaco9425
    INFERNOtaco9425 Roll Tide! ChopOn!
    Chad
    Decatur, Alabama “River City”
    2019 SSM DCSB TRD OR 4x4 Prem&Tech
    My DRLS come on as soon as I turn my truck on, even in park.
  5. Mar 22, 2019 at 9:51 AM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    What about ebrake.
  6. Mar 22, 2019 at 9:51 AM
    HacksawMark
    HacksawMark Well-Known Member
    Mark
    OREGON
    2018 Silver Tacoma V6 DCSB TRD OffRoad traded for 2019 Ford XLT 3.5L EcoBoost SC
    This ^
  7. Mar 22, 2019 at 9:52 AM
    HacksawMark
    Mark
    OREGON
    This also ^
  8. Mar 22, 2019 at 9:55 AM
    INFERNOtaco9425
    Chad
    Not sure about the ebrake since I rarely use it. I do keep my DRL to the on position when I turn the truck off tho.
  9. Mar 22, 2019 at 9:56 AM
    INFERNOtaco9425
    Chad
    That’s not how my DRLS work.
    birdieking33 likes this.
  10. Mar 22, 2019 at 9:56 AM
    ICU1
    ICU1 Well-Known Member
    Interesting.
    But, does the light really go out when the refrigerator door is closed?
    verynearlypure likes this.
  11. Mar 22, 2019 at 9:59 AM
    INFERNOtaco9425
    Chad
    Showed my daughter the other day and yes it does go off. It’s magic to my eyes and hers too lol.
  12. Mar 22, 2019 at 10:18 AM
    DCJeeper
    Just tested it again. This is probably the reason. Turn on the engine with parking brake on, DRL not working. Then release the brake, switch to DRL and it’s on. Now with the engine still on, turn off DRL, pull the break up again, turn DRL on, it works. So the break has to be release at the first time then DRL works. No transmission R or D is required. Will see how it works tomorrow morning.
  13. Mar 22, 2019 at 11:06 AM
    ICU1
    Also, when you use your turn signal, the direction (left/right) your turning, will automatically turn off that side DRL.
  14. Mar 22, 2019 at 11:07 AM
    ICU1
    It’s all witch-craft and magic.
  15. Mar 22, 2019 at 11:12 AM
    INFERNOtaco9425
    Chad
    That is not true for the led drls. The sr5’s drls tho are their turn signals.
  16. Mar 22, 2019 at 11:13 AM
    ICU1
    Good to know
  17. May 10, 2022 at 3:46 PM
    area51auto
    area51auto New Member
    Thank you INFERNOtaco942...I have been trying to figure out why my LED (white) running lights don't work on my 2022 SR5 for a week now. I came to the conclusion that the running light was the signal (orange light) once I realized it was coming on instead of the light trim piece around a quarter of the housing. Kinda sucks that the LED trim piece is even there if it's not functional. Crazy that it's $1000 to upgrade to the LED lights.
