Daystar 1" Coil Spacers = 2" Lift
Discussion in 'Suspension' started by lucky, Jul 20, 2008.
  1. Jul 20, 2008 at 4:32 PM
    lucky
    lucky [OP] Well-Known Member
    NB, TX
    07 PreRunnerX4
    After getting the Leaf spring TSB 3 weeks ago, I decided I wanted the truck to be level again.
    I read a number of threads about the actual lift a 1" spacer would provide, I had resigned to the fact it would only be 1".
    I purchased the Daystar 1" kit from 4WheelParts in San Antonio - $44.
    After about 3 hours of an install, I am pleased to announce the lift is 2". See before and after pics.
    By the way - AutoZone offers a free tool loan program. Your deposit is the cost of the tool. Bring back tools, get all your money back. I picked up a spring compressor and ball joint tool, I already had everyhting else.
  2. Jul 21, 2008 at 4:28 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Any spacer you put on the front will always be 1/2 the lift amount.
    1" spacer = 2" lift
    1/2" spacer = 1"
    That's because the shock/coilover assembly is mounted in the middle of the A-arm (fulcrum - hard to explain).
  3. Jul 21, 2008 at 10:15 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    3 hours? give it 3 months... the springs will settle...
    :D
  4. Jul 22, 2008 at 2:15 AM
    Janster
    Jandy
    Lancaster, PA
    Coils don't settle.
  5. Mar 1, 2009 at 6:50 PM
    canuck_tacoma
    canuck_tacoma Well-Known Member
    BC, Canada
    SR5 4X4 Tacoma Access Cab
    1.5" Eibach Front Coil Lift, Rear TSB, 265/75/16 BFG A/T's
    I ordered the Daystar 1"lift, actually the 4 runner budget lift, which is the Tacoma 2.5 without the spring isolator. So I guess I should expect 2 inch's? A little annoying because I was going to go with the 5100's but decided, $700 wasn't worth the price (Canada) for a 1 inch lift. I will post my observations after it gets done.
    It looks like the Pre-Runners sit higher, to begin with, than the 4X4's? My SR5 is sitting at 34.5 and his was at 36 before lift.
  6. Mar 2, 2009 at 5:55 PM
    KoolWipTacoma
    KoolWipTacoma Member
    Lynchburg Va
    05 Taco DB Cab 4x4
    lots with update soon!
    dont forget about tire size! You and him may be running different sizes to make yalls total hight different.
  7. Mar 9, 2009 at 9:00 AM
    markvfr
    markvfr Member
    Calgary
    02 Tacoma TRD Xtra Cab
    Bilstein 5100
    I'm in Calgary and got the 5100's all around for $295US from Downsouth. My stockers were shot so I had to replace them anyways. Local stealers wanted like you said $700 for stock replacements!! Eff that. I got the 5100s and AALs for $75 and I got a 2inch lift out of it. Pretty much a free upgrade if you consider the cost of the stuff locally. Super happy with the 5100s. Amazing improvement over stock (shot) shocks. :) I put the front at the middle 1" setting but will move it up to the 2.5" setting this weekend.
    Don't give up on the 5100's. If you need more info, drop me a PM.
    Cheers,
    M
