Daystar 2.5" leveing kit Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 27taco1988, Dec 17, 2010.
  1. Dec 17, 2010 at 5:20 PM
    27taco1988
    27taco1988 [OP] Active Member
    Cody
    Stafford, VA
    '10 2.7L 4x4
    I have a 2010 Tacoma and i ordered a Daystar 2.5" leveling kit with the coil spacers up front and blocks in the rear. I have the Bilstien TRD struts and shocks. The guy at 4Wheel Parts said im gonna need longer shocks. Is that true?
  2. Dec 17, 2010 at 5:40 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Meh.. Shoulda came on here and asked a question before you bought that lift. You will have a rough ride, and no you don't need longer shocks, the point of the leveling kit is to lower the strut to make a lift, but it's bad for the suspension geometry causing it to have a rough ride. You will regret buying this lift. You should of got the Bilstein 5100s and adjust them to a 2.5 setting and have the same height lift for a few extra bucks and got it done the right and safe way in first place.
  3. Dec 17, 2010 at 5:51 PM
    27taco1988
    Cody
    Stafford, VA
    '10 2.7L 4x4
    screw it ...just ordered a set of 5100's after doing my research and seeing the carnage that comes from coil spacers. haha i guess ill have to learn from my mistakes
  4. Dec 17, 2010 at 9:39 PM
    WABOOM
    WABOOM Well-Known Member
    Minnesota yeah sure ya betcha
    2013 F-150 XLT Supercrew 4x4
    debadged
    I love forum's
  5. Dec 17, 2010 at 9:42 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    True.
    Longer shocks are not needed. I got my money back after they figured out it was not necessary to install them. They even tried to charge my for the shocks even though they didnt install them - good thing I looked at my reciept.
  6. Dec 18, 2010 at 12:14 AM
    27taco1988
    Cody
    Stafford, VA
    '10 2.7L 4x4
    so you have the daystar leveling kit still installed? have you have any problems whatsoever with it?
    and thanks everyone for your input. i really appreciate it
  7. Dec 18, 2010 at 3:52 AM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    2x
