Daystar 2.5" spacers install question??
Discussion in 'Suspension' started by davidjmay, Jan 1, 2013.
  1. Jan 1, 2013 at 12:14 PM
    davidjmay
    davidjmay [OP] Well-Known Member
    David
    Orange County/Azusa
    '00 PreRunner
    Pioneer HU & door speakers, Alpine type R, Kicker dx1000.1, OME 883 lift, Wheelers 2" AAL, custom mesh grille, smoked LED taillights, LED light bar, Raptor exhaust dumped before axle, custom fabbed roll bar/light bar mount
  2. Jan 1, 2013 at 2:58 PM
    Anthony250
    Anthony250 Ex Fabricator
    Anthony
    Rialto CA
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    Those Go on top of the coils. You take apart the strut, swap out the bolts to the longer ones, put it back together and put the spacer on top then bolt it in.
  3. Jan 1, 2013 at 7:20 PM
    davidjmay
    David
    Orange County/Azusa
    '00 PreRunner
    so that means spring compressor. right?
    Well I picked em up for free. I've got a front end OME setup, but I'm waiting to put it in until I get something for the rear, as 3" front + nothing in the rear =mega bro lean. What was your problem with the daystar spacers?
  4. Jan 1, 2013 at 9:31 PM
    Anthony250
    Anthony
    Rialto CA
  5. Jan 1, 2013 at 10:31 PM
    davidjmay
    David
    Orange County/Azusa
    '00 PreRunner
    Don't do much off roading, so it wont be a problem. Just need something until I get enough cash for the dakars. But my question is even though its just the top spacers (doesnt preload the spring), does the coilover still need to be taken apart? Apparently the answer is yes.
  6. Jan 1, 2013 at 10:35 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    You're not stacking them with the OME right? Cause that would be BAD....why install twice, I'd just wait and do it all at once or bro lean it for awhile!
  7. Jan 1, 2013 at 10:49 PM
    davidjmay
    David
    Orange County/Azusa
    '00 PreRunner
    Hell no haha. Im planning on just doing the spacers for now until I get dakars, then swap everything out and throw in OME front and rear (take off the daystar spacers obviously). I think the OME with 883's in the front would just be too much bro lean, thats why I'm waiting to put them in until I get the rear as well.
  8. Jan 1, 2013 at 11:29 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
  9. Jan 2, 2013 at 10:13 PM
    Eagledynasty
    Eagledynasty The White Knight
    AJ
    Worcester, MassHole
    09 Super White DoubleCab Off-Road
    2009 SWDC O/R. Check Build!
    Yes compressor is needed to answer your question.
    No it will not preload and cause harm. BUT even the 2.5" with stock rear will give you about 3/4" brolean.
  10. Jan 2, 2013 at 10:35 PM
    Sigi
    Sigi Well-Known Member
    Sigi
    Sfv ca
    06 tacoma 4x4 trd offroad
    You don't need a spring compressor . I have the same thing and was really easy to put on. You just add some extended bolts and add the spacer and them put it back on. And all these people saying that your going to break something I wouldn't worry about it . I bet none of them have ever had a spacer and broke something . I personally have one and have taken my truck offroading to some black diamond trails and many other tough trails for 2 yrs and have never had a problem . I wheel my truck all the time , so you should be fine. But recently ordered a full lift kit but still waiting for it.
  11. Jan 2, 2013 at 10:44 PM
    davidjmay
    David
    Orange County/Azusa
    '00 PreRunner
    :confused: :confused: one of you is lying...
  12. Jan 2, 2013 at 10:47 PM
    davidjmay
    David
    Orange County/Azusa
    '00 PreRunner
    Majority answer is that I will need a spring compressor, but I dont see why I would need one, UNLESS the spacer goes below the top plate? But that would mean preloading the coils, and this spacer does not. So I don't see where a spring compressor would be needed.
  13. Jan 2, 2013 at 10:52 PM
    Sigi
    Sigi
    Sfv ca
    The spacer sits on top with out disassembling it. If it went in between then why would it come with extended bolts ?? I have one . I'm right . Lol
  14. Jan 2, 2013 at 10:54 PM
    VanCity4x
    VanCity4x Well-Known Member
    AB
    05 Tacoma
    3link on tons
    Dont NEED spring compressor.
    Im running this lift. Its a bitch to install, have to seperate the uca and lca as far as possible to make fit. Disconnect tierod end link, balljoint, take the shock out, put the cap on w/ thread extenders and put back in. Compressing springs might make it easier to put back in tho but not necessary.
  15. Jan 2, 2013 at 10:54 PM
    davidjmay
    David
    Orange County/Azusa
    '00 PreRunner
    ^see, that's what I'm thinking. Thanks for the assurance :thumbsup:
  16. Jan 2, 2013 at 10:56 PM
    davidjmay
    David
    Orange County/Azusa
    '00 PreRunner
    Eeek, this I'm not stoked about. I could see where a spring compressor would help, but man that doesn't sound fun. How did you separate the lca from the uca?
  17. Jan 2, 2013 at 10:58 PM
    VanCity4x
    AB
    05 Tacoma
    3link on tons
    Watch the ball joint when you put it back togeather, make sure theres no play. Impact helps to keep it from spinning. Get alignment right after too.
  18. Jan 2, 2013 at 11:00 PM
    VanCity4x
    AB
    05 Tacoma
    3link on tons
    Its tight to work around the hub, sway bar ect. Had 2 guys seperating them while I forced the strut back in. It took time but eventually it went in. Worst case, take the spacer off and put it back to stock.
  19. Jan 2, 2013 at 11:01 PM
    VanCity4x
    AB
    05 Tacoma
    3link on tons
    You have first gen tho? Might be different
  20. Jan 2, 2013 at 11:08 PM
    ae111black
    ae111black Well-Known Member
    Kimo
    Hilo Hawaii
    2013 Trd Sport
    plenty
    Ok folks! OP yes you need to disassemble the strut to get the studs in. Yes you need to undo some front end components to get it in. Yes you will NOT break things in slow speed off situations. There's thousands of these spacers on trucks out there and yes there has been some failures. OP keep it slow and you'll be fine. Personally I'd wait and do all the OME at once.
