daystar kit and cv joint
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rbohno, Mar 22, 2017.
  1. Mar 22, 2017 at 4:46 PM
    Rbohno
    Rbohno [OP] Well-Known Member
    Richard
    Charlotte,NC
    2010 DC TRD OffRoad
    Viper remote start alarm 2.5" Spacer in front, 1.5" spacer in rear, rear TSB performed N-Fab Nerf bars 16" x 8" Vision Warrior wheels 265/75/16 Dura Trac tires
    I had local Meineke install Daystar spacer kit, mgr said 2.2 hrs labor I said okay and dropped it off at 8am this morning, he said it would be done by noon.
    At 2:00 I called and owner said guy was having trouble with it and I didnt get truck till 5:00pm. I live 6.5 miles from shop and by the time I got home I heard rattling under front drivers side.
    Pulled into drive crawled under neath and it looked like a grease bomb had gone off behind the drivers side wheel.
    Took truck back to the shop and owner said "Oh yeah when you change the drive angles of the cv joints they will blow"
    I said you may be right but I have run 2" spacers on many Tacoma's and never had a problem.
  2. Mar 22, 2017 at 4:48 PM
    Rbohno
    Richard
    Charlotte,NC
    2010 DC TRD OffRoad
    This was on my 2015 DC TRD Offroad Sport
  3. Mar 22, 2017 at 4:57 PM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Bullshit!
  4. Mar 22, 2017 at 5:14 PM
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    Is it CV boot grease or front diff fluid? Former is black and sticky, latter is clearer and stinky.
    The "mechanic" either tore the CV boot or pulled the whole shaft out of the diff trying to get the spacer in. I'd be pretty unhappy - but not surprised from a Meineke shop.
    Good luck getting them to fix it - if you used a credit card dispute the charge, that usually gets their attention.
  5. Mar 22, 2017 at 5:42 PM
    Rbohno
    Richard
    Charlotte,NC
    2010 DC TRD OffRoad
    Its thick grease, my brother said he bet the mechanic pulled too hard on the tripod when trying to get the spacer with extenders into place
    Justinlhc likes this.
  6. Mar 22, 2017 at 5:43 PM
    Rbohno
    Richard
    Charlotte,NC
    2010 DC TRD OffRoad
    I put it on my company AmEx but i hope it doesn't get to that
  7. Mar 22, 2017 at 5:44 PM
    Rbohno
    Richard
    Charlotte,NC
    2010 DC TRD OffRoad
    or he tore the boot with the pickle fork
  8. Mar 22, 2017 at 5:51 PM
    Rbohno
    Richard
    Charlotte,NC
    2010 DC TRD OffRoad
    I just wanted to get folks opinion on the spacer kits and the possible causes. My thought process was that since the shop manager stated if anything changes the cv joint angle it will damage it then
    A) Why would he put it on
    B) How could they (Daystar) sell them
    C) If that were the case wouldnt even 5100's alone clicked up to 2" cause the same issues?
    I wheel this truck on the property behind the house but 90% of its use is running service calls all over the state and into the mountains.
  9. Mar 22, 2017 at 6:22 PM
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
    Mechanic was sloppy and tore the cv boot. The CV angles will not be that extreme with only a 2" lift. He shouldn't have even needed to undo the balljoint on the bottom, so no pickle fork would have been used. My guess is he undid the bottom shock mount, and tore the CV boot putting it back in.
  10. Mar 22, 2017 at 6:35 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    That was my first thought. That's why it took so long.
