Daytime Amber Lens Melted...
Discussion in 'Lighting' started by Blacked Out TRD, Jul 9, 2009.
  1. Jul 9, 2009 at 11:16 PM
    Blacked Out TRD
    Blacked Out TRD [OP] Well-Known Member
    08 Tacoma Double Cab Blacked Out
    TRD Heated Leather Seats, Blacked Out Hadlights, Black Powder Coated Wheels, Red Emblems, HID's, Tinted Front Windows, many more to come
    I did the mod where your turn signal light is on with your Daytime Running light which gives you a nice bright amber light. Looks really nice. Problem is the extra lite element gave out extra heat which melted my amber lenses inside the headlight. Anyone else have this happen. I need to find a LED Amber light that doesn't give off heat like a standard bulb does. Any suggestions?
  2. Sep 2, 2009 at 12:50 PM
    warpwr
    warpwr Junior Senior Member
    Vaughn
    S.F. Bay Area
    09 Sport Access Cab
    DRL mod with switch, rear spring TSB, trans TSB, tailgate mod, snug-top shell.
    I was wondering about the possibility of that happening.
    I ordered the parts to do the DRL mod and I found this website for LED lamps.
    http://www.eautoworks.com/search-ALL/mk34-ca4.htm
    I haven't received the parts yet so I haven't investigated what the bulb number is though.
    They have an inline resistor you can buy if the turns don't work because of low resistance too.
    http://www.eautoworks.com/product-Led-33226.htm
    I will replace the stock bulbs for sure now that I read your post. Thanks.
  3. Sep 2, 2009 at 1:41 PM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    He said he had the turn signal on and the DTRL. It ws that extra heat that melted the housing. He didn't say it was the dtrl mod. nor did he say it was the oem one.
  4. Sep 3, 2009 at 10:57 AM
    warpwr
    Vaughn
    S.F. Bay Area
    09 Sport Access Cab
    Oh...
    I don't know what mod he did then but he could still use the LEDs though, right?
    The mod I'm going to do is called the DRL mod. It uses the amber turn indicator lights. And it is the same as OEM using Toyota parts.
    Here's what the mod says in part...
    "What you will be doing is replacing the current TURN SIGNAL RELAY with a new one + a jumper. The new relay will turn your FRONT TURN SIGNALS on when you don't have your headlights on and you are moving. This allows your truck to be seen better in all driving conditions."
    I just assumed that's what he did too.
  5. Sep 3, 2009 at 11:16 AM
    shockittillyareconizeit
    shockittillyareconizeit Well-Known Member
    Dustin
    California
    '07 Coma PreRunner
    Front - Icon 2.5 Coilovers, Maxtrac 4" lift spindles, TC UCA's Rear - Billy's 5100/1.5 AAL, 3" lift blocks MB Predator wheels - 16x8 plasti-dipped matte black Toyo Open Country A/T 305/70/16 Satoshi grille Blacked out badges DTRL Wet Okole seat covers
    Yeah, that's the mod that he did also. DTRL and DRL is the same thing. I just recently did the mod also. I haven't encountered any problems yet, but then again, i don't have them on for extremely long amounts of time as maybe he did.
    I'll be lookin out for the update on this LED amber light. If it's bright enough, maybe i'll change mine also just as precaution.
  6. Sep 3, 2009 at 1:02 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    Delray Beach, FL
    2007 Infiniti G35S
    WHY would you ever do that??
  7. Sep 3, 2009 at 3:37 PM
    rb11701
    rb11701 Oh yeah!
    Rob
    There are 2 different DTRL mods. One is the same as an OEM install and would be the same as if it came right from the dealer. The other one taps into a wire. The OEM install makes use of the blinkers just like before the mod. The other (which I think he did) uses the turn signals and keeps them on. Thus the brigher light.
    Then again, I could be way off on this. But Idoubt the OEM mod would melt the glass. LED's would work BTW. Might have a cool look.
  8. Sep 5, 2009 at 7:47 PM
    Plain Jane Taco
    Plain Jane Taco You....out of the gene pool.
    Bill
    USA
    2015 DCSB TRD Sport PreRunner
    I pretty sure the bulb in the front signals is a dual filament type. So when the DRLs are on both filaments are burning to make them quite bright....so it does get quite hot. But I wouldn't think hot enough to melt the lens! I've got factory DRLs with no issues. It almost make you wonder if Toyota uses 2 different headlamp housing, depending on whether the truck has DRLs or not.
  9. Sep 6, 2009 at 11:32 AM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    dtrl's are only a 40 dollar option so i doubt it.
  10. Nov 6, 2009 at 7:20 AM
    OVTaco
    OVTaco New Member
    Dave
    Norfolk, Va.
    06 SR5 Dbl. Cab 4X4 all options
    TSB Suspension upgrade, Red Line Hood Struts, Wet Okle Seat Covers, XM custom install
    I have an 06 w/70K miles on it and factory DTRL's. The lenses are scorched yellow, cracked and appear to be melting away. The dealer says I have an electrical problem causing both filaments to burn thus causing the meltdown. I don't believe them. Any other 06 owners out there w/ factory DTRL's that could take a look and let me know if both filaments burn?:confused:
  11. Nov 6, 2009 at 7:42 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    North DFW
    07 DCSB Sport 2wd
    5100s @ 0.85, Grom iPod/Bluetooth adapter, mud flaps removed, clear turn signal bulbs, two extra D-rings, debadged, fog light anytime, OEM bed mat, Undercover classic, Falken Wildpeak A/T3W, Fumoto valve
  12. Nov 6, 2009 at 8:24 AM
    Viet2100
    Viet
    Delray Beach, FL
    2007 Infiniti G35S
    LEDs FTW.
  13. Nov 6, 2009 at 8:33 AM
    VissionMx
    VissionMx Socialist States of America
    Chase
    Canyon Lake, CA
    06 PreRunner Sport Dbl Cab
    DTRL,Blinker DTRL, fogs anytiime, relocated and blacked badges, Decepticon emblem(by MetalMiller)
    <-------I have LEDs in my running lights and my turn signals.
    the only problem is the leds use less power so you will get hyper flashing with the turn signals. you will have to get a resistor also...i think
    like this
  14. Nov 20, 2009 at 7:33 AM
    OVTaco
    OVTaco New Member
    Dave
    Norfolk, Va.
  15. Nov 20, 2009 at 12:01 PM
    Viet2100
    Viet
    Delray Beach, FL
    2007 Infiniti G35S
  16. Nov 20, 2009 at 12:18 PM
    warpwr
    Vaughn
    S.F. Bay Area
    09 Sport Access Cab
  17. May 1, 2010 at 6:42 PM
    Dare_n
    Dare_n Member
    Hawaii
    08 D-Cab 4x4 SB
    5% tint N-FAB STEPS WET OKOLE SEAT COVERS AFE INTAKE AFE THROTTLE SPACER
    I have a 2008 Tacoma Sport with the Stock DTRL's, and my inside lens of the blinkers are making the plastic bubble. My friend just had his replaced for warrenty. He had a 2007 Tacoma Offroad. I think the bulb gets to hot for the len's.
  18. Jun 8, 2010 at 1:06 AM
    hamads
    hamads Member
    Hawaii
    05 Double Cab Sport
    i've got the same problem, mines got bubbled and is now cracked...anyone know exactly why? im thinking that bulb is too hot.
  19. Jul 7, 2011 at 6:17 AM
    Joe in the hills
    Joe in the hills Well-Known Member
    Joe
    Cleveland, SC
    Timberline Mica SR5 TRD Offroad Towing Pk
    TJM Bull Bar Bumper, 7100 Bilstiens on FE, 4 Leaf Spring Retro
    I just discovered that I have the same problem. The drivers side is discolored and cracked whereas the passenger side has what looks to be bubbles appearing in the amber plastic. My truck has over 36K miles, but I got the extended platinum warrenty from Greenfield Toyota in MA so it will be covered.
  20. Oct 1, 2011 at 9:31 PM
    WhiteTacoma09
    WhiteTacoma09 Faketannydeluxe
    Curt
    summerville, sc
    09 Prerunner access cab
    ZXE Headlights Drop in k&n filter Kobalt slim toolbox Tinted 17" FJ trail edition wheels OEM foglights 265/70/17 BFGs AVS vent visors Pioneer AVH-X1500DVD
    I have a 2009 with no dtrl at all. Did the mod that just jumps a wire from side marker. It makes the light now "on" but not super bright. Only get brighter with second element when blinker is applied. I can see this melting if both filiments are constantly on tho. Anybody have theirs melt with a mod like mine?
    should I worry, only been a few days since mod.
