Daytime Running Light Burnt Out
Discussion in 'Lighting' started by tacom08, May 7, 2013.
  1. May 7, 2013 at 1:32 PM
    tacom08
    tacom08 [OP] Well-Known Member
    Isaac
    Simpsonville, SC
    PreRunner Rugged Trail Edition SSM w. locker
    CIPA Corner Wedge Blind Spot Mirrors, Garmin GPS, squeaky seatbelts mod
    Just noticed today that my left Daytime Running Light is not working at all (burnt out). You can see that the faulty DRL is "burnt/melted".
    http://www.youtube.com/watch?v=q-zPG8UZypQ
    I know that DRL lens melting/cracking is a common issue on the 2nd gens. However, I couldn't find anybody on the forums mentioning DRL's ceasing to function.
    Truck has ~42,000 miles and was bought new back in '08, so obviously, the warranty has expired.
    My main questions here are:
    Can I fix this by myself at home?
    How much do repairs cost?
    Any help would be appreciated.
  2. May 7, 2013 at 1:35 PM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Overland Build
    Millions
    It's like a $2.00 bulb at Vatozone. Extremely easy to replace.
    Edit: Because I'm feeling helpful today I looked up the part for you. Looks like they're sold in pairs. You should probably replace them both.
    http://www.autozone.com/autozone/pa...tbh6Z9cjds?itemIdentifier=89682_665333_19345_
    Sylvania/Daytime Running Light Bulb
    For your 2009 Toyota Truck Tacoma 4WD 4.0L EFI DOHC 6cyl
    Part Number: 3157-4157NALL
    Alternate Part Number: 3157NALL B2
    $5.99
  3. May 7, 2013 at 1:45 PM
    tacom08
    Isaac
    Simpsonville, SC
    Thanks for the help.
  4. May 7, 2013 at 1:53 PM
    PinkTaco24
    PinkTaco24 Well-Known Member
    NC
    06 prerunner
    5100s all around -- 1.75 fronts, 1.5 aal, spidertraxs, grillcraft mx, derped scoop & badges, AVID step bars....need.more.money.
    If you get 3057A, it will not generate as much heat, hence alleviating even more lens melting. I run these in mine. The appearance is the same. Have had zero issue in the year+ that I've had them.
  5. Aug 16, 2013 at 9:03 PM
    ETAV8R
    ETAV8R Out DERP'n
    Republik of Kalifornia
    MGM 09 AC 4WD V6 TRD-OR w/ 2013 FWC Finch
    Grillcraft, Demello Sliders, Bilstein front and rear with OME coils and springs, Wheelers Bumpstops front and rear
    Good stuff here. Wish I had replaced my stock bulbs long ago.
  6. Aug 16, 2013 at 9:21 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Watch them carefully, there's less than 2 watts difference in the spec for the 3057 vs 4157.
  7. Aug 17, 2013 at 4:55 AM
    PinkTaco24
    NC
    06 prerunner
    Will do, thanks. I've ran these for over a year with no problem, but that was with aftermarket housings. I just recently went back to stock, so I am definitely keeping my eye on them. I hate that this is such an issue with these trucks.
Products Discussed in this Thread
