Daytime Running Lights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jimdq4u, Mar 6, 2016.
  1. Mar 6, 2016 at 9:38 AM
    jimdq4u
    jimdq4u [OP] Active Member
    Jim
    Philadelphia
    2012 Red Tacoma
    I added some LED's along my grill by tapping into the daytime running lights. I tapped into the green wire and it works fine however when I turn the headlights on I lose power to my LED'S. Weird because the power stays on to the Daytime running lights so ANY idea why>
  2. Mar 6, 2016 at 9:47 AM
    YDCtaco
    YDCtaco Well-Known Member
    Alexandria, VA
    2016 DCSB TRD OR 4x4-Auto
    The led drls on my Tacoma dim when the headlights turn on, so if you tapped in that connection, it would make sense that those lights would dim. Unless you don't have the led drls....
  3. Mar 9, 2016 at 8:10 PM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    OP, could you give a little more info? Was this a LED kit with resistors, or did you just buy some LED strips and install. Also, what truck do you have, do you have LED DRLs. The more info we have, the more we can help. Right now I would say it is a voltage load issue.
  4. Mar 29, 2016 at 10:31 AM
    jimdq4u
    Jim
    Philadelphia
    2012 Red Tacoma
    Thanks team...I figured it out. There are two different Power sources going to the LED's DRL's on the 2016 Tacoma. When you go from just DRL to all lights it switches power sources so just needed to tap into both.
  5. Mar 29, 2016 at 10:32 AM
    YDCtaco
    Alexandria, VA
    Give some pics of your grille leds
  6. Mar 29, 2016 at 6:54 PM
    rooney2oons
    rooney2oons Well-Known Member
    Dallas, Tx
    2016 TRD Off Road Silver
    Nothing yet....im a poor bastard.
    and post pics of where you tapped into the lighting as well.
  7. Mar 30, 2016 at 12:51 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    This...^^^^^^^ Please
