DBA rotors
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2WD, Aug 10, 2023.
  1. Aug 10, 2023 at 8:03 PM
    2WD
    2WD [OP] Well-Known Member
    Pete
    2013 DCSB TRD Off-Road Pre-Runner Taco
    King 25001-119A, JBA HC and superbumps, EL095 leafs with longer overload leaf removed and 2 degree shim, Bilstein 5160 rears with fox roost shield on passenger side, King 2'' bump stops, B&M 70264 trans cooler, CSF FJ radiator, Leer Trilogy X2T bed cover, Scangauge, 34R AGM battery, weathertech floormats, Gold plug on the differential, fancy engine and diff oils, UNI air injection filter mod, Factory antenna chopped 4'', De-badged, Ram mount on A pillar, Cooper ST Maxx 265/75 R16.
    Does anyone have some miles behind rotors made by DBA? Which ones do you have and do you recommend them? I'm planning a brake job this winter and there isn't much talk about them.
