DBLCAB LB frame Rivet?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jdtemple, Jul 25, 2010.
  1. Jul 25, 2010 at 9:01 AM
    jdtemple
    jdtemple [OP] Well-Known Member
    Bay Area CA
    08 DBLCAB LB TRD Sport
    Lift & Tires, in cab power outlets, Locking Bed Boxes, K&N
    I searched for the terms, but couldn't find anything.
    If you follow the rear cab mounts down to the frame you will see a riveted mount on the underside of the frame. There are spots for 2 rivets on each side. Does your truck have both rivets?
    EDIT : Added pics.
  2. Jul 25, 2010 at 9:04 AM
    VooDoo
    VooDoo More Cowbell!
    Carter Ivey
    Baton Rouge, LA/ Starkville, MS
    '06 DC LB PreRunner
    i'm not sure i understand your question?
  3. Jul 25, 2010 at 9:04 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
  4. Jul 25, 2010 at 9:05 AM
    Rucas
    Rucas 1st gen > 2nd gen
    Lucas
    Northern Colorado
    1st gen. 4x4 MANual
    sparkles, fairys, and happy things.
    ?? maby i could take a look later.
    Why do you ask?
  5. Jul 25, 2010 at 9:24 AM
    jdtemple
    Bay Area CA
    I am chasing a popping or a click sound down, and discovered a spot where 2 rivets could have been.
    Where the rear cab mount is mounted to the frame, there is also a cross member that goes from the driver side to the passenger side of the frame. There is currently 1 rivet and 1 hole where a rivet could have gone on each side on the bottom side of the frame. The empty hole doesn't line up very well all the way through, so maybe it's just another hole on the frame. It I looks like the only spot on the frame that would have to rivets side by side (within an inch or so of each other)
    I will post a picture when I take one today.
    EDIT : Pics Added in 1st post.
  6. Jul 25, 2010 at 3:18 PM
    jdtemple
    Bay Area CA
    I looked at a brand new short dblcab short bed and it did not have the holes riveted either. Must be normal.
