Dc-dc charging
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Theobald75, Jun 23, 2025.
  1. Jun 23, 2025 at 4:39 PM
    Theobald75
    Theobald75 [OP] New Member
    Putting a bluetti charger1. (Fast charger) in rig for my new topper. Will only be used while driving to charge my bluetti AC200L power pac while heading to new locations. Will I need a heavy duty alternator for this set up? Also, could someone verify if my 2014 Tacoma 2.7 has a smart alternator or not. I found nothing attached to negative cable on battery at terminal to say it was a smart alternator. Is this all I need to look for, I do not yet have a meter to watch draw.
  2. Jun 23, 2025 at 5:17 PM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    What's the wattage output of your DC-DC charger?
  3. Jun 23, 2025 at 7:24 PM
    Theobald75
    560 watts
  4. Jun 23, 2025 at 8:07 PM
    agent4573
    agent4573 Well-Known Member
    2015 Xtra cab, TRD O/R
    None yet
    Youre on the limit. 2.7 liters came with a 100 amp alternator. The charger draws 50. The normal capacity of your battery is ~80 amp hours, and lead acid batteries charge at around 0.2C, or ~16 amps in your case. So that brings you up to 66 amps if the batteries are fully dead. It's normally recommended to not exceed 70% rated capacity on the alternator, so you'll be close to the recommended limit, and likely over when also running the truck and other accessories, especially at night.
    That being said, frequency of you having 2 batteries <80% and needing to have headlights on and stereo cranked, and etc. etc. is likely not a common occurrence. I would run the 100 amp until it dies, then replace it with a bigger one for piece of mind.
  5. Jun 23, 2025 at 8:37 PM
    Theobald75
    Much appreciated. Everything you said made sense with all I have read, just could not put it together like that myself.
  6. Jun 23, 2025 at 8:54 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    The alternator is internally regulated, it's temperature compensated but that's about the extent of it's "smarts".
    Typical charging voltage on these is around 13.7-14 cold and 13.2-13.4 hot.
    Voltage is sensed on the S-Terminal (Pin 1 (White)).
    Some people "trick" it into charging at a higher voltage so they can use an AGM battery by replacing the ALT-S fuse with a diode, that drops the voltage at the S-Terminal by about 0.5v so it charges around 0.5v higher than it normally would.
