DC rear passenger power window stuck down
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ecrepeau, May 30, 2012.
  1. May 30, 2012 at 3:15 PM
    ecrepeau
    ecrepeau [OP] Well-Known Member
    The rear passenger window has been sporadically working. Will always go down, but won't always go up. Told the wife not to use it and well that didn't get listened to, so. Is there a way to manually get the window up?
    Also, what are the thoughts on the problem? The master switch or the motor? Since it will always go down wondering if it is the switch and since it will just not go up and then at some point will not thinking it is the motor unless it is seizing up somehow.
  2. May 30, 2012 at 3:26 PM
    Aw9d
    Aw9d That one guy
    Az
    Motor would be my first guess. Take it apart, they aren't too hard to work on.
  3. May 30, 2012 at 3:27 PM
    TnRedNeck721
    TnRedNeck721 GO VOLS!
    Zach
    TN
    07 TRD off road 4WD
    i say take the door panel off and see what you can see/find maybe something falls and blocks it from going up. idk just a thought. if not it’s prob the motor or switch.
    edit: or maybe something like the lock button... i have done that a few times. but when looked it wont go down or up.
  4. May 30, 2012 at 3:28 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Does the rear switch work?
  5. May 30, 2012 at 3:34 PM
    ecrepeau
    Yeah checked previously to make sure nothing was blocking it from going up.
    The safety lock out switch isn't engaged.
    When it happens neither the driver switch or the rear door switch works.
  6. May 30, 2012 at 4:13 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    And the other switches/windows function when this occurs?
  7. May 30, 2012 at 5:33 PM
    ecrepeau
    Yup, all other switchs and windows function fine. If you keep trying either the driver switch or the switch on the window itself it will (knock on wood) eventually decide to listen and the window rolls up.
  8. May 30, 2012 at 7:20 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    I'm betting it's the master switch. The ground circuit runs back through it.
  9. Aug 9, 2012 at 7:27 PM
    mistaare
    mistaare Well-Known Member
    silver. sport.
    I am experiencing the same thing with the same window. Did you ever determine the problem? Mine is an '09 with only 37,000 miles and the window is already breaking? YIKES!
  10. Aug 10, 2012 at 6:37 AM
    ecrepeau
    After it working sporadically it has been working without issue. My plan was to disassemble and check the motor first and if that worked fine I was going to then check the master switch.
    Mine hasn't acted up since so I have left it alone until or if it acts up again. If it is the master switch I wouldn't buy directly from Toyota as they are crazy for how much they want for the part. You can find it aftermarket with lifetime warranty for way less. Motor you can find cheaper but without warranty, but for the price difference I think you could buy like 2 or 3 of the aftermarkets for the same as Toyota wants.
  11. Aug 10, 2012 at 6:55 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    If the window travels in one direct, the motor is fine. Being a DC motor, they reverse direction by changing the polarity. So if a window only travels in one direction, the problem is in the reverse direcrtion circuitry.
  12. Aug 13, 2012 at 8:32 AM
    ecrepeau
    Yeah I think the revival of this post jinked me. Over the weekend mine acted up again. I am leaning towards it being the master switch that is going bad on me and I am planning on ordering a new one this week.
